Old 03-04-2018, 07:17 PM   #1
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Weird sound from HVAC
Strange sound coming from the HVAC. Sounds like it’s coming right from the front vents. Even when the air is turned completely off. Any thoughts?
Kronos is offline   Reply With Quote
Old 03-04-2018, 07:55 PM   #2
BRZnut
Drives: BRZ DGM Limited
Haven't heard that one before. Does it change if you have the blower motor running?
Old 03-04-2018, 08:39 PM   #3
Kronos
Kronos's Avatar
Good question, short answer is no.
changing the airflow from off to 1,2,3 or 4 makes no difference in the sound.
Yeah I’ve been on this forum for years and I’ve never run across this sound before. It’s freaking me out
Old 03-04-2018, 10:35 PM   #4
That's the cooling fan in the radio.
Old 03-05-2018, 12:31 AM   #5
Is the sound that you are hearing, sound like a lamb bleating off in the distance ... ??
Old 03-05-2018, 06:02 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
As @Ultramaroon said I'd put money on the two (or one) little 60-80 mm fans in the head unit. Sounds like a bad bearing in them. Removing the radio is quite easy to check and isolate the sound. Also I'm assuming they're PWM type fans so they could be an easy fix without replacing the head unit
Old 03-06-2018, 03:40 PM   #7
Kronos
Kronos's Avatar
Oh so there are actually little fans in the headunit?? I legit thought @Ultramaroon was just trolling
Thank you guys for the advice. I will definitely pull out the unit and check. It was really starting to get to me. I was starting to seriously consider the bleating lamb theory
@humfrz i loled
Old 03-06-2018, 03:46 PM   #8
@humfrz i loled
I hear tell, that the sound of bleating lambs goes silent when ol @Ultramaroon goes out into the barn ......
Old 03-06-2018, 06:16 PM   #9
@humfrz i loled
I never shitpost in a tech thread until after the question/topic has been properly discussed.
True story.
weird sound when accelerating in low RPMs evoto86 Engine, Exhaust, Transmission 37 12-18-2020 02:40 PM
Weird sound over 60mph FRiSson Issues | Warranty | Recalls / TSB 23 03-05-2018 11:47 AM
engine got weird sound hands0me Issues | Warranty | Recalls / TSB 14 07-29-2016 06:07 PM
weird engine sound Stratoside Issues | Warranty | Recalls / TSB 52 01-13-2016 03:05 PM
This might sound weird mrha BRZ First-Gen (2012+) — General Topics 10 10-06-2012 06:06 AM
