Old 07-09-2012, 10:32 PM   #15
Grace
Drives: Honda CRX
Originally Posted by Flat Black VW View Post
Since we technically do these as aftermarket systems, although we do them on mostly brand new cars for dealerships who add them as a factory option for the customer for financing, none of ours come with drill hole positions or templates, we simply measure them out and mark the spots before drilling.
I would definitely not consider the FR-S a difficult car. There is plenty of room behind the bumper and running wires through this car is cake. What I consider a difficult car and would have to upcharge for would be a Lamborghini, Ferrari, Mclaren, Ect. These are cars where I must run wires past an engine, they have minimal room behind the bumpers, and panels inside the car are a PITA to take apart properly. Even with these difficulties it simply takes more time and I still would only be at around $600 to install rear sensors on these cars.
Thank you very much!
I am feeling very well informed =]
Grace is offline   Reply With Quote
Old 07-09-2012, 10:34 PM   #16
Grace
Drives: Honda CRX
Originally Posted by sesmls View Post
I just bought ordered one of these to warn me of impending doom to the lower front of my car:
http://www.southerncarparts.com/curb-alert-p-3474.html
They make a version with a smaller sensor for $259.00 or this one for $159.00
I haven't seen this before.
But, how is this different from a parking sensor?
Curb feelers?... no thanks... the car will look handicapped.
Old 07-09-2012, 11:53 PM   #17
Bairex
Drives: Mazda Millenia
Parking sensors
I have installed the ultrasonic type on my Mazda. I will on the BRZ once I get it. The sensors have saved me from being hit and from hitting others backing out of a parking lot.
Furthermore, I can't count the number of time that small kids on a parking lot, barely tall enough to be seen thru the rear windshield have crossed behind my car and the sensors have detected them.
Yes, I had to drill. You have to be very careful, you only have one shot at this. Where you locate them will also affect how they perform.
I got mine from this place: http://www.carsensors.com/Home.html . They sell them painted to match the bumper.
Bairex is offline   Reply With Quote
Old 07-10-2012, 02:04 AM   #18
sesmls
Drives: DGM BRZ Limited, 05 Baja Turbo
This is a parking sensor, but doesn't require drilling holes in your bumper...the sensor mounts with adhesive (or however else you want to mount it) behind the grille, low to the ground. You set the angle of the sensor and it gives you a warning (which can be muted) when the front of your car gets too close to a curb or post.
sesmls is offline   Reply With Quote
Old 07-10-2012, 07:05 PM   #19
poudre
Drives: Silver Limited
Originally Posted by jcs View Post
poudre is offline   Reply With Quote
Old 06-13-2013, 04:54 AM   #20
Alfalasy
2013 BRZ
Alfalasy's Avatar
I find this very useful especially with an extended lowered front lip
Alfalasy is offline   Reply With Quote
Old 06-13-2013, 05:12 AM   #21
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
I was going to say back up camera, but, really, the car is so small how do you need sensors to park? Maybe it is the fact that my dad really engrained into me to know the size of the vehicle that I am driving, but honestly, the FR-S is one of the easiest cars to park that I have ever owned. No disrespect.
Demandred7 is offline   Reply With Quote
Old 06-13-2013, 09:10 AM   #22
Ryuu0u
(=^・ェ・^=)
Ryuu0u's Avatar
Drives: 2013 FRS, '08 GSXR 600
I'd say save your money and just be more attentive. Like others said this car fairly small. Most parking spaces I have almost 6in-1foot on each side and parallel parking I can fit in quite comfortably. Just use your judgement and you'll be fine.
Ryuu0u is offline   Reply With Quote
The Following User Says Thank You to Ryuu0u For This Useful Post:
strat61caster (06-13-2013)
Old 06-13-2013, 11:46 AM   #23
Stryker
Drives: 2000 Subaru Forester
The $1,000 figure is cheap, sort of.
If you want to get the OEM Park assist that is available in Australia, for the parts (uninstalled) you're looking at ~950 USD. Plus you would need to get it shipped. This is the price for front and rear, but honestly...just get a back up camera and be done. This car is not hard to park from what I've experienced (test driven it twice).
Stryker is offline   Reply With Quote
Old 06-13-2013, 12:08 PM   #24
zaptorque
zaptorque's Avatar
Drives: 2013 Asphalt FR-S
I have some parking sensors....they're called my eyes.
zaptorque is offline   Reply With Quote
Old 06-13-2013, 05:01 PM   #25
root
Drives: Raven FR-S
Well, I just backed into the end of a chainlink fence with the right rear corner. Was pretty sickened when I heard it. I'm still not used to the additional width of the FR-S I guess. Should have moved the sideview mirror, but it was night in a poorly light spot so probably wouldn't have helped much. Oh well, first major scratch. A lot of it buffed out and it was all on the plastic so no dent damage. I'm going to live with it, not worth going to paint shop for.
The FRS like lots of cars nowadays has pretty high rear deck so I can see some value in sensors.
But you have to wonder when you see Smart cars with backup sensors, these people would need backup sensors on their butts!
root is offline   Reply With Quote
Old 06-13-2013, 06:18 PM   #26
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
might i suggest a rearview camera? most mount just on your licesnse plate frame. Plus good excuse to get an aftermarket headunit. Some headunits even offer two channel camera inputs so you can mount a tiny cam up front too
mrlewistan is offline   Reply With Quote
Old 06-13-2013, 09:29 PM   #27
FRiSson
Drives: FR-S MT
Rear view license plate cam (bluetooth or not) is a better deal.
FRiSson is offline   Reply With Quote
The Following User Says Thank You to FRiSson For This Useful Post:
PhantomX (11-24-2015)
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 04:22 AM
Update on TPMS - No light without sensors! trueno86power Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 05-11-2014 03:45 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 01:22 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 04:24 PM
Auto Parking Sensors? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 84 02-18-2012 02:01 AM
