#15 |
Drives: Subaru BRZ
In order to dial in the proper camber with the SPC, you may have to loosen/adjust the toe simultaneously. One time the alignment guy couldn't get pass -1.5 no matter how much he turned the cam bolt. Then as soon as he loosen the toe adjuster, it went to -3.
#16 |
Drives: 2014 Asphalt FRS
Ah I see. The tech said if I had any issues or wanted a change he would do it for free so I will give him one more try. How exactly do you adjus the camber on these? Isn’t the ring supposed to hit a notch on the arm or something?
#17 | ||
Drives: '23 BRZ
-2.1 rear camber is fine as long as you keep rear toe minimized. I'd go for zero rear toe. Quote:
![]() Can't speak to clunking issue... |
#18 | |
And also he was able to get .2mm toe in the left rear with -1.3 camber, but the best he could do was .4mm with -2.1 camber on the right rear. So that led me to believe he doesn’t know how to adjust the lower control arm possibly |
#19 |
Drives: Subaru BRZ
As you turn the camber bolt, it (round silver ring) pushes against the notch on the arm, thus the bottom portion of the knuckle goes out. If you loosen the toe arm in front, that'll give it more room to play with.
#20 | |
Drives: '23 BRZ
sin-1(0.6mm/627mm) = 0.05° total, that's near enough to zero. But yeah, with adjustable arms you'd think you could get it where you want it. |
| Alignment question. | ohnoitsthefuzz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-09-2015 07:33 AM |
| Alignment Question | Covo_86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 06-04-2014 11:37 AM |
| brz alignment question | Shenks | BRZ First-Gen (2012+) — General Topics | 2 | 02-12-2014 09:23 PM |
| alignment question | hanabie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-15-2013 12:52 PM |
| Alignment question | retrosmiths | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-11-2013 10:44 PM |
