Old 02-05-2018, 01:25 AM   #29
turtlefeeder
turtlefeeder's Avatar
Drives: UltraMFrS
Any confirmation about Velox Level Bracket working with other LCA?
turtlefeeder is offline   Reply With Quote
Old 03-03-2018, 02:41 PM   #30
Carbinebbq
Carbinebbq's Avatar
Drives: 2017 BRZ Limited
Hey guys, if anything this might help. I was about to get the wrong arms.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Carbinebbq is offline   Reply With Quote
Old 03-03-2018, 05:48 PM   #31
churchx
churchx's Avatar
Drives: 2014 GT86
SPC are same as Whiteline's and as Eibach's, just different paint/slight differences in pricing. Don't know, whose it's original, whose rebranded. They all are stock-alike stamped steel except eccentric bolt for camber adjustment, so yes, that should all have mounting hole for headlight beam height adjustment.
Velox kit is designed to fit exactly holes cut in velox LCA. I highly doubt that kit being usable for any other aftermarket LCA unless it's some chinese-ebay shameless exact copy of Velox's.
Imho best bet would be to measure approximately where/how should adjustment kit be mounted on stock arm and make some hack-up simple mount in some local shop for LCA one has. Imho should be simple enough with some plate bent around arm and with screw hole where need to be.
Old 03-21-2018, 02:31 PM   #32
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
The Megan racing ones work fine with the stock leveling bracket though, I have the megan racing LCA on my 2017 BRZ and it has a slot to bolt in the OEM leveling bracket.
mjanmohammad is offline   Reply With Quote
Old 04-23-2018, 09:35 AM   #33
slim blanco
slim blanco's Avatar
Drives: 2017 86
just to bump this since i'm having the same problem with my 2017 86. i lowered it this past weekend, and while the rs*r rlcas i put in have the mount point for the rod on the sensor, my headlights point straight at the ground now since the sensor thinks the suspension in the rear is very compressed.
i read something about detaching the arm on the sensor, setting the headlights level by manually moving it, and then unplugging the sensor so they don't move on their own anymore. i'll probably give that a shot, since it's the cheapest/easiest solution. i don't care for the auto adjustment anyway and i don't usually have a lot of extra weight in the car other than myself.
i also tried adjusting that knob on the back of my headlights...it didn't do anything for my headlights that are pointing at the ground about 20 feet in front of my car. i'm guessing adjusting the knob on the headlight had no affect because the sensor on the rlca is so maxed out haha. going to give this a shot after i get home today though, hopefully it works.
slim blanco is offline   Reply With Quote
Old 04-24-2018, 05:54 PM   #34
slim blanco
Drives: 2017 86
a quick update with mine...
i just disconnected the linkage from the rlca, removed the arm from the sensor, and slightly turned the end of the bolt that was left sticking out in order to adjust the headlight level. worked fine for me. i don't plan on hooking the arm back up, because it's not that important of a feature for me.
i asked ft86speedfactory if they offered an adjustable link to replace the oem link that attaches the sensor arm to the rlca, and while they didn't when i asked, they now offer the cusco one, if anyone wants to keep the system hooked up.
The Following 2 Users Say Thank You to slim blanco For This Useful Post:
Andyxin (05-08-2018), Plumbus (10-11-2020)
CAUTION: 2017 REAR CAMBER ARM PROBLEM with Performance Package 007BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 01-11-2021 04:24 PM
Has anyone ACTUALLY driven their car without the headlight leveling sensor? Var Cosmetic Modification (Interior/Exterior/Lighting) 11 12-27-2017 10:39 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
Auto Headlight Sensor Conector Help!!! kmbkk BRZ First-Gen (2012+) — General Topics 5 06-04-2013 09:43 AM
