Old 11-01-2017, 08:56 PM   #1
Var
Drives: 2017 Subaru BRZ PP
Has anyone ACTUALLY driven their car without the headlight leveling sensor?
I'm just curious what happens. Curious about either
1-electrical harness disconnected or
2-harness connected but sensor not bolted to control arm
Do the headlights point all the way up?
All the way down?
Somewhere in between?
Does the computer freak out?
Var is offline   Reply With Quote
Old 11-01-2017, 09:02 PM   #2
All the way down?
Every single FRS owner as driven without headlight levelers. About 98% of the car driver on the road have driven without them. Set them in the center and pull the plug if you don't want them.
Somerandom18 (11-01-2017)
Old 11-01-2017, 09:42 PM   #3
Poodles
Drives: 2015 Series.Blue
Wait, if you're in California we don't have auto levelers in the states.
Old 11-02-2017, 01:54 AM   #4
NRXRaptor
My BRZ's headlights and yours have a leveling motor. I don't have the lights anymore but they were there. I don't understand leveling motors: they add cost and complication that can go wrong. Same with HIDs and integrated leds and projectors. I know they look nice in photographs but now I'm blinded by everyone and their mom who did an HID conversion at night in this low car. Thank god the twins don't have "collision detection," front and side facing cameras, night vision cameras that only work when the headlights are on (hi mercedes) or any other crap like that
NRXRaptor is offline   Reply With Quote
Old 11-02-2017, 02:58 PM   #5
Var
You can't set anything on 2017 and newer. They don't have any manual adjustment anymore. So I'm wondering what would happen without it
Old 11-02-2017, 03:12 PM   #6
If you unplug it in a flat neutral place it will be centered. Once unhooked from the sensor it will not move.
Dadhawk (11-02-2017), spike021 (11-06-2017), Var (11-02-2017)
Old 11-02-2017, 07:54 PM   #7
Poodles
Yes, and they're manually adjusted in my car.
OEM HID's =/= HID kit garbage
One is legal and non blinding, the other isn't. Retrofits are a gray area. If done right they're as good as OEM if not better.
Why remove it? If you lower the car there are adjustable linkages for that. Not like it's really hurting anything...
Old 11-06-2017, 04:56 PM   #8
TheLowlyThird
Drives: '17 Toyota 86
When I installed aftermarket LCA's (on a 2017) there wasn't a spot for the headlight sensor so I just kinda left it hanging. My headlights were pointed so far up I couldn't see to drive home and had to zip tie the sensor to my LCA on the side of the road. Hope that helps.
TheLowlyThird is offline   Reply With Quote
Old 11-06-2017, 05:19 PM   #9
HachiRolle
Drives: 2017 Toyota 86
I’ve been running without the sensor connected to the LCA since February or so. I disconnected the arm off of the headlight sensor, and turned the positioning knob on the sensor itself until they leveled to where I wanted them. Haven’t had an issue since.
HachiRolle is offline   Reply With Quote
The Following User Says Thank You to HachiRolle For This Useful Post:
slim blanco (04-23-2018)
Old 11-06-2017, 06:15 PM   #10
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
my LCA had the slot for the leveling sensor but the lights were pointed way too high after the car was lowered. I used the 8mm nut on the back of the headlight to adjust them down. Took 15 minutes.
mjanmohammad is offline   Reply With Quote
Old 12-27-2017, 09:03 PM   #11
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i was under the impression if you lowered your car, and left the headlight level arm connected to the LCA, it would angle the headlights down constantly because it thinks the back is heavily loaded and so the ass of the car is sagging down.
Surok is offline   Reply With Quote
Old 12-27-2017, 10:39 PM   #12
nico_rsx
Drives: BRZ 2017 Pure Red, MT
That's also what I thought and I had trouble getting an answer, but someone told me that yes, that's what happen, but there is a manual adjustment in the back on each headlight, that you can use to bring them back level again.
http://www.ft86club.com/forums/showt...34#post3011221
nico_rsx is offline   Reply With Quote
Wtb: BRZ headlight leveling wire harness D3MON_86 Want-To-Buy Requests 0 06-06-2017 02:52 PM
BRZ Driver Headlight Leveling not working Decimus Cosmetic Modification (Interior/Exterior/Lighting) 0 05-10-2017 07:49 PM
Strange Noise from Headlight Leveling Module Stang70Fastback Issues | Warranty | Recalls / TSB 1 07-10-2016 12:14 AM
DIY: Headlight leveling dial for BRZ (and maybe GT86) headlights on FRS Chaetagnath DIY (Do-It-Yourself) Guides 2 01-15-2016 01:55 AM
Auto Headlight Sensor Conector Help!!! kmbkk BRZ First-Gen (2012+) — General Topics 5 06-04-2013 09:43 AM
