#29 | |
Drives: Honda Accord Euro
[ame="https://www.youtube.com/watch?v=0r8xW03PVow"]STI flexible tower bar movie - YouTube[/ame] |
#30 | |
Drives: 2019 Mazda Miata RF
So, that said, the flex brace may be an improvement over no brace, but it's still offering more compliance than a solid brace. |
#31 | |
Drives: '15 BRZ RA
#32 |
![]() ![]() The top chart is the 86, and the lower chart is an e46 on a track. Positive numbers mean the chassis is spreading apart, and negative means the chassis is spreading inward. The STi bar can prevent these motions, but what these graphs don’t show is when you hit a bump and part of the chassis moves up relative to the other. A stiff strut bar makes these bumps pretty brutal (looking at the Focus RS) but a bar that flexes during these kind of movements makes the ride more compliant, which can actually handle better over rough roads or imperfections on the track. |
#33 |
Drives: 2017 BRZ
#34 |
Only happy when it rains.
Drives: series.blue
just like the chassis of a car, or even simpler, a soda can, they are designed to be flexible in only certain directions, and rigid in others.
#35 |
Drives: BRZ 2018
The more friendly/compliant a car is at the limit the more easier you reach your personal limits, this is my personal experience.
By the way just found another flexible strut tower bar from SYMS made also by Yamaha as TRD/STI one: https://syms.jp/car_category/bodysupport_brz86zczn/ |
#36 |
Drives: 2014 BRZ Limited A/T
Sorry to revive this thread, but is this the conclusion?
To mod an other-wise non Ts Car, 1. Best for DD, just slap on a Flexible V-Bar 2. Best for DD, and some more stiffness, Flexible V-Bar + Draw Stiffener 3. Iciing on the cake thats not as necessary: Tower Bar + V-Bar 4. All the way - Tower Bar + V-bar + Draw stiffener? |
| The Following User Says Thank You to leevanf For This Useful Post: | norcalpb (02-02-2019) |
#37 |
Drives: '15 BRZ RA
Just keep in mind to keep the stiffness balance front and rear. I had option 1 and I was quite happy. I installed recently the thicker rear oem sway bar and now I am going for option 2. So, it depends the total balance of the car ...
#38 | |
Drives: BRZ 2018
#39 |
Drives: '15 BRZ RA
If you have the latest chassis changes (+'17), then yes option 2 is recommended. Leevanf has the '14 model which is weaker on the rear. He could still go with option 2, but I believe only if he makes some changes on the rear too. Of course all these would be noticeable when driving on the limit and with stickier tires. Otherwise, there will not be visible any weakness.
#40 |
Drives: BRZ 2018
Just installed draw stiffeners and STI flexible tower bar in my MY18 BRZ.
I do feel the front end to follow faster the steering inputs and the car feels comfortable than before believe it or not! That's very interesting and explains why the flexible bar is better than any aftermarket bar (independent vertical movement of each front strut towers) while I feel the need to add the harder STI steering rack bushes as the response of the front end is probably more than the feedback - or at least this is my feeling - so I should equalize them, bear in mind I also have the tS suspension so very close to this setup. |
#41 | |
Thats awesome. I dropped my suspension mod route on favor of getting forged wheels first. What made you decide to get the flexible tower instead of the flexible V bar? Sent from my iPhone using Tapatalk |
#42 | |
Drives: BRZ 2018
By searching the net I found also that STI steering rack bushes are quite difficult to install so I may install aftermarket ones say Whiteline etc. |
| Flexible Draw Stiffener and Flexible Tower Bar | Maxwell | BRZ First-Gen (2012+) — General Topics | 5 | 01-11-2015 11:43 AM |
| Amp draw | sw20kosh | Electronics | Audio | NAV | Infotainment | 4 | 08-20-2014 01:54 AM |
| Subaru STi - flexible draw stiffener | illmatic | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 11-29-2013 11:04 AM |
| Draw your BRZ! | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 14 | 09-26-2013 01:34 PM |
| Blow through vs draw through MAF | mrk1 | Forced Induction | 9 | 07-24-2013 07:21 AM |
