Old 03-01-2018, 07:58 AM   #1
stlgrym3
which is the best drop in air filter for automatic BRZ
K&N, HKS Hybrid, Perrin or something else?
stlgrym3 is offline   Reply With Quote
Old 03-01-2018, 08:35 AM   #2
They are all about the same with no real "best". You just need to decide if you want oiled or dry. The TRD one is very good as well but costs a bit more than the others on your list.
Old 03-01-2018, 09:33 AM   #3
jjorgen
jjorgen's Avatar
Drives: 2016 Scion FR-S
I completely agree with Tcoat. I do have the AFE dry filter and really like it so that also might also be one for you to consider.
jjorgen is offline   Reply With Quote
Old 03-01-2018, 10:00 AM   #4
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I have afe dry as well. I don't want to have to oil the filter when cleaning it.
Some generalities to consider:
More surface area, better overall flow.
Better filtration from media, less efficient flow.
Greater capacity media, longer you can run the filter efficiently.
Oiled media generally has higher efficiency and capacity, but doesn't collect the smaller particulates as well as non-oiled media It works by bending air around sharp corners and flinging dirt into the oil in the filter, trapping the dirt. Having the right amount of oil is critical to filter performance
Non-oiled, or dry, media forces air through small openings which physically catch dirt particles and hold them in place. Less efficient, but more predictable and consistent filtration.
The Following User Says Thank You to Spuds For This Useful Post:
Boomerang (03-02-2018)
Old 03-01-2018, 10:28 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
I have the Takeda Momentum CAI and I'm loving it.
Old 03-02-2018, 02:56 AM   #6
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
My personal preference would be dry filters. Less chance of gunking your maf if you over oil or whatever
tyler_win_photo is offline   Reply With Quote
The Following User Says Thank You to tyler_win_photo For This Useful Post:
JazzleSAURUS (03-02-2018)
Old 03-02-2018, 03:11 AM   #7
stlgrym3
does the TRD one fit our BRZ?
Old 03-02-2018, 04:51 AM   #8
tyler_win_photo
Yes.
Old 03-02-2018, 08:10 AM   #9
stlgrym3
just ordered TRD filter from FT86 Speed Factory.
FS: k&n drop in air filter BRZ'13 Canada Classifieds 6 01-16-2016 02:31 PM
FS: TRD Drop in Filter atomedge Canada Classifieds 8 10-23-2015 09:15 PM
Best Drop In Filter BRZ_STI Engine, Exhaust, Transmission 21 07-22-2014 03:36 PM
Best air drop in filter to get atm? rhood168 Engine, Exhaust, Transmission 23 05-13-2013 06:44 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
