Old 02-28-2018, 11:12 AM   #1
JDM4E
Drives: Honda Accord Euro
OEM looking catch can with easy emptying
I am looking for a catch can, single but I don't mind if dual, that looks OEM-ish in the engine bay (=no crazy colors, huge logos, transparent hoses etc.) and that you can easily empty.
I was checking radium for example, and it seems you have to disassemble things to empty it, which is no-no. So I need some easy access, accessible drain valve or something. I don't want vent to air since that is illegal here.
Thanks
JDM4E is offline   Reply With Quote
Old 02-28-2018, 11:29 AM   #2
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
The Velox unit has a nice drain plug on the bottom. You could even get their adapter plate kit that, after it has been filtered, it drains back into the engine.
https://www.verus-engineering.com/pr...-oil-separator
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
JDM4E (03-06-2018)
Old 02-28-2018, 11:36 AM   #3
elBarto
elBarto's Avatar
Drives: Toyota GT86
I have the RacerX catchcan. It has a drainage valve at the bottom, everything is included (hoses, clamps, mounting bracket).
Already collected 0.5L of gunk with it in 10.000km of driving.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 02-28-2018, 11:52 AM   #4
Grady
Grady's Avatar
Get an AOS instead of catch can. Then you do not have to worry about draining.
Old 02-28-2018, 01:53 PM   #5
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I went with the Mishimoto model MMBCC-BRZ-13P for that very reason. It was easy to coverup the labels and ease to clean.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
JDM4E (03-06-2018)
Old 03-01-2018, 12:59 PM   #6
KL
Drives: 2013 SWP BRZ
The radium can has a drain port on the bottom. You can buy a drain valve kit from them to make it REALLY easy to drain. As it is, undoing 3 bolts doesn't exactly take long.
Sent from my Pixel using Tapatalk
KL is offline   Reply With Quote
Old 03-06-2018, 01:09 PM   #7
JDM4E
The Mismimoto looks looks good and it seems the opening could be easy.
Radium has drain kit, but you have to have any other thing to drain to; plus it seems it is a hassle next to the battery; plus the green fittings are no-no.
Velox looks also good, but how safe is the "back to the engine" thing? And you said it has been filtered, do you must change/clean any filters than?
Any easy way to fix this? Kev Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 05-15-2016 12:01 PM
Easy way to empty your catch can...maybe BirdTRD DIY (Do-It-Yourself) Guides 7 04-15-2016 09:18 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 12:04 PM
