-   -   OEM looking catch can with easy emptying (https://www.ft86club.com/forums/showthread.php?t=125724)
JDM4E 02-28-2018 11:12 AM
I am looking for a catch can, single but I don't mind if dual, that looks OEM-ish in the engine bay (=no crazy colors, huge logos, transparent hoses etc.) and that you can easily empty.
I was checking radium for example, and it seems you have to disassemble things to empty it, which is no-no. So I need some easy access, accessible drain valve or something. I don't want vent to air since that is illegal here.
Thanks
Jesse36m3 02-28-2018 11:29 AM
The Velox unit has a nice drain plug on the bottom. You could even get their adapter plate kit that, after it has been filtered, it drains back into the engine.
https://www.verus-engineering.com/pr...-oil-separator
elBarto 02-28-2018 11:36 AM
I have the RacerX catchcan. It has a drainage valve at the bottom, everything is included (hoses, clamps, mounting bracket).
Already collected 0.5L of gunk with it in 10.000km of driving.
https://kek.gg/i/3HDshG.jpg
Grady 02-28-2018 11:52 AM
Get an AOS instead of catch can. Then you do not have to worry about draining.
FLYFISHR 02-28-2018 01:53 PM
I went with the Mishimoto model MMBCC-BRZ-13P for that very reason. It was easy to coverup the labels and ease to clean.
Attachment 163359
KL 03-01-2018 12:59 PM
The radium can has a drain port on the bottom. You can buy a drain valve kit from them to make it REALLY easy to drain. As it is, undoing 3 bolts doesn't exactly take long.
Sent from my Pixel using Tapatalk
JDM4E 03-06-2018 01:09 PM
The Mismimoto looks looks good and it seems the opening could be easy.
Radium has drain kit, but you have to have any other thing to drain to; plus it seems it is a hassle next to the battery; plus the green fittings are no-no.
Velox looks also good, but how safe is the "back to the engine" thing? And you said it has been filtered, do you must change/clean any filters than?
