Old 02-27-2018, 05:36 AM   #15
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by churchx View Post
Captain Snooze: weren't there during development/release of mishimoto's(?) silicon intake tube some dynos, that showed slight gains with sound tube delete/slight losses with resonators delete? My memory may mistaken of course.
Given my memory I have no idea but then again I've never had much interest in Mishimoto products. If the dynos were posted by Mishimoto call me a sceptic.
Old 02-27-2018, 06:24 AM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Found it, if it's of interest. Seems both on mishimoto & oem and both with oem filter & highflow one best resonator left+soundtube delete, close to it were both left or just resonator delete, and worst - both deleted. Gains/losses were slight enough to possibly fall within dyno error (and to care much for) though, but as trend was somewhat same for oem tube/mishimoto one and with oem airfilter & aftermarket one, it might be true aswell.
Captain Snooze (02-27-2018)
Old 02-27-2018, 01:07 PM   #17
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Wise View Post
I've heard Mishimoto's ZX tyres are amazing.
Mashimoto ZX*
Old 02-27-2018, 02:33 PM   #18
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
It's a poor (as in zero) return on investment, but whatever floats yer Brrrrz...
Raceseng Circuit Sphere 100 shifter arm, Radium catch can and master cylinder brace, Perrin oil cooler, Vorshlag front camber plates, ACE A350 header & overpipe, Berk catted front pipe, CSGxMXP exhaust, Delicious NA Stage II tune & Flex Fuel
JSube is offline   Reply With Quote
Old 02-28-2018, 06:24 AM   #19
JSube
JSube's Avatar
Hey churchx, (off topic because, why not, intakes don't do jack) but nice job Latvia in the Winter Games. Bronze in the sled and Silovs was so close in speed skating!!
The Following User Says Thank You to JSube For This Useful Post:
churchx (02-28-2018)
Old 02-28-2018, 04:56 PM   #20
ChuBRZ
Drives: 2017 BRZ |Yellow series/Limited|
Firstly, thanks for reviving a 2&1/2 year old thread.
Secondly, how does one get a pressure drop due to the sound hose? I mean it is not open ended; it is sealed at one end. I am suggesting that any adverse resonance would be negated by the relatively large volume of the chamber it is attached to.
Thirdly, I would love to see proofs. This is the first I've read of power loss due to the sound/noise tube.
LOL You're welcome! I don't actually have data myself, but, Mishimoto did do some research on the matter. What I can tell you is that I changed mine 2 days ago, and I felt my other mods synergizing. Mishimoto claims the inlet peace will net 5hp. I'm running an e85 tune, UEL coated header, coated overpipe, full Ark DT-S exhaust with optional test pipe. I threw on a K&N drop in because im gonna cut the factory box for now.
Now... To explain the science. Air is not very dense so changes to the size and shape of its container can result in changes in pressure on moving air (pressure waves). The intake resonator also helps to reduce turbulence in the intake so you need it. This will in turn cause changes in pressure in the cylinder robbing you of power because their might be less volume of air in the mixture. These constant changes will also ruin your gas mileage. 2 days and I see a huge improvement in gas mileage even using e85. By the way... The same principle can be applied to the exhaust. That is why people use heat wraps and thermal coating. It keeps the heat trapped in the header so the gases can evacuate more quickly creating negative pressure (pressure waves), and thus removing more exhaust to ensure a more efficient combustion on the next cycle.
ChuBRZ is offline   Reply With Quote
Intake Tube - Is the resonator necessary? Perrin, Mishimoto, et al.... Chad_W Engine, Exhaust, Transmission 25 07-21-2015 11:37 AM
FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD johnb831 Engine, Exhaust, Bolt-Ons 13 05-21-2015 05:27 PM
Mishimoto Radiator & Blue Mishimoto Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 6 03-24-2014 10:34 PM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 08:44 AM
Hello from Mishimoto! Mishimoto Announcements, Contests, Giveaways 12 07-05-2012 06:18 PM
