#43 |
Drives: 2017 BRZ
Do you know if the blown engines have abnormal wear on their rod bearings upon tear down? I think it's possible that the oil film is being squeezed out when the oil pressure is low (low rpm) and torque is high. If the film is squeezed out then metal-on-metal contact between then rod and crank would sharply increase the compressive force in the rod.
#44 | |
Drives: GT86 Harrop S/C
For that reason you may have done better with a centrifugal kit. However, it then wouldn’t feel much different to stock at around 2-3k rpm which is where most normal driving happens..... Can’t win!! Like you, despite these draw backs I would still recommend FI to anyone who knows they will be keeping the 86 for a while, and who isn’t goong to get carried away, crank the boost up and snap a rod. |
#45 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
The Edelbrock didnt give me the kick in the pants feeling like you get with a turbo. But because theres added power all across the band, i couldnt get past 5k without already being at 90 mph. And seeing as how i dont hoon around a ton i missed being able to rev that high. I agree, if i went with a JRSC i probably would still be running the kit. Only because when you do hit that 5k RPM limit, its almost like hitting Vtech (i had an S2000) which is really fun. Either way i think since most of my driving is in the 3-4k rpm range, i'd rather have the turbo kick.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
| The Following User Says Thank You to Xxyion For This Useful Post: | Irace86.2.0 (02-27-2018) |
| Any recommendations for building a motor locally? | eherschend | Northern California | 11 | 02-19-2017 12:45 AM |
| Building my motor I need help on which pistons and rods and which ones to get at a | Anthony7515 | Engine, Exhaust, Transmission | 23 | 09-21-2014 10:03 PM |
| Building a motor before turbo? | ikeryder13 | Forced Induction | 25 | 11-04-2013 09:04 AM |
| Best deal on Building motor | Fabron757 | Engine, Exhaust, Transmission | 0 | 06-29-2013 09:20 AM |
