Old 02-26-2018, 05:48 AM   #43
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The batt terminal may look fine visually, and a lot of people make a mistake by leaving it be and spend a lot of $$ to chase other "problems" at garage that may not be so reputable. But they'll always be "nice". So after a BS TB service, injector "cleaning" and several wallet flushes the problem still exists.
Remove the battery terminals with a 10mm socket. Clean the terminals and posts with a wire brush no matter how good they look. Reassemble and observe.
guybo is offline   Reply With Quote
Old 02-26-2018, 11:24 AM   #44
JERM^
JERM^'s Avatar
Drives: WRB BRZ Aozora 15'
Done all these this morning. Car started up fine just like yesterday at noon. Now it's just a waiting game. Hopefully a very long waiting game. Thanks for all the help guys.
JERM^ is offline   Reply With Quote
Old 02-26-2018, 11:29 AM   #45
How did everything look?
Old 02-26-2018, 11:40 AM   #46
JERM^
JERM^'s Avatar
Well... No visible white substances or anything. Gave the baking soda + wirebrush treatment and put WD40 on battery terminals anyways. Tightened the connectors more tightly this time.
Car started fine just like Saturday so can't really tell if it did anything LOL.
Old 02-26-2018, 11:41 AM   #47
Iffen that don't work, Bubba says to put second battery post clamp on it .....
Old 02-26-2018, 11:45 AM   #48
JERM^
JERM^'s Avatar
That must have done it.
Old 02-26-2018, 11:55 AM   #49
Good show!
Did you put WD-40 directly on the battery posts ... ??
I don't know whether that would set up them for a "varnish" like barrier to a good connection or not......
@Tcoat will chime in ...... he has a lot of past experience with old junk batteries ......
Next time, I'd suggest it would be OK to put a squirt of WD-40 on the clamps bolt's threads ...... but, I'd leave it off the post itself.
Old 02-26-2018, 11:58 AM   #50
JERM^
JERM^'s Avatar
Good show!
WD40 markets themselves for this very use
https://wd40.co.uk/knowledgebase/pro...als-corrosion/
Old 02-26-2018, 12:02 PM   #51
Good show!
Cleaning contacts is one of the things it was made for. It will be fine.
https://www.wd40.com/img/WD-40_2000_uses.pdf
Old 02-26-2018, 12:24 PM   #52
Oh, OK ...... what a list !...... I'll take your word for that ...... too much fine print for my old eyes.
Sorry for the unwarranted concern, there OP .....
Old 02-26-2018, 12:29 PM   #53
Good research!
(back in my day, we just used a mixture of coal oil and 3in1 oil to loosen stuff up ...... didn't want to put that on batter terminals ..... )
humfrz - stuck in the 50's
Old 02-26-2018, 12:42 PM   #54
Good research!
When did you make it that far?
Oh wait you didn't specify which "50s"
Old 02-26-2018, 12:56 PM   #55
Be prepared for more chasing. Never hit the same spot twice. When you find it, you'll know it.
Old 02-26-2018, 01:14 PM   #56
JERM^
JERM^'s Avatar
Yea will do and next diagnostic will likely be as per @e30kawi.
Originally Posted by e30kawi View Post
I've had this issue in the past, where the car won't crank one minute and the next it will. One time was a bad connection at the solenoid and a couple other times the solenoid was on the way out.
It's my understanding that once the solenoid goes bad or starts to go bad, it will or can try to draw twice the cranking amps as it normally would, making it seem like a weak battery.
ECUTek Cable, Engine Mounts, Raceseng Crank Pulley, Intake Tube, Light Battery Kit jonesy Engine, Exhaust, Bolt-Ons 1 08-25-2017 10:46 AM
Crank No start (Not battery issue) NEED HELP cnxmist Issues | Warranty | Recalls / TSB 19 07-28-2017 05:44 AM
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
KW V3: 16 clicks for compression? h3opama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-02-2015 08:01 PM
FS Phantom Supercharger PC680 starter battery, new display-2050 alex345 Engine, Exhaust, Bolt-Ons 20 04-12-2015 01:00 PM
