Old 02-25-2018, 11:12 AM   #295
blkdmnd
Drives: Black 2015 Subaru BRZ, BlackDiamond
Just installed mine after having invidia catless fp and N1, put stock fp and cbe on, then gruppe-s op and headers. Also getting the rattly/hissing noise near the connection of the header and op. almost louder than the exhaust itself sometimes
blkdmnd is offline   Reply With Quote
Old 02-25-2018, 11:44 AM   #296
Teseo
Drives: frs
Chek for leaks, put soapy water in spray bottle and spray a little while engine running where leaks are suspected
Old 02-25-2018, 03:27 PM   #297
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Originally Posted by Its_Will View Post
So i was thinking of either purchasing these or perhaps the OFH or the tomei. As i am reading through the forum i keep seeing posts about the header making weird noises. So now i am a little shaky on them. Could anyone shed some light on the Gruppe-s ? if you were able to find a solution?
No weird noises after 2 years
Sent from my SM-G950U using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
Old 02-25-2018, 06:39 PM   #298
blkdmnd
So that is what it would sound like? I tightened it as much as I could im pretty sure. I also used washers that came with it, maybe I'll take those out.
Old 02-25-2018, 06:40 PM   #299
blkdmnd
No hissing sound for you at all? did you use oem hardware or from them? what about gaskets?
Old 02-25-2018, 06:43 PM   #300
Strife26
Strife26's Avatar
Oem parts only. Maybe it's there, but I've never noticed it.
I've had it 2 years, added 2 different fp/op setups, 2 exhausts, and installed a turbo and no headers sound that I've noticed besides that sexy subie rumble.
Old 02-25-2018, 08:30 PM   #301
blkdmnd
I really wonder if it's the hardware they sent like the gaskets. Where'd you get your gaskets from? Also should I use oem nuts and bolts?
Old 02-25-2018, 11:56 PM   #302
Jasten
I think i'm experiencing the same thing from the same area. This whole time I was thinking it was my front pipe since its my last stock exhaust piece, but I guess i'll go check that area. I checked for a leak and I don't think that's it. that raspiness/rattle only happens at cold start and sometimes when accelerating.
Jasten is offline   Reply With Quote
Old 02-26-2018, 02:07 AM   #303
Strife26
Strife26's Avatar
Came with it or reused idr
Old 02-26-2018, 08:28 AM   #304
blkdmnd
Mine happens a decent amount when accelerating but I can’t always hear it with windows up. I’m almost 100% it isn’t a leak bc I felt around the area while it was being revved and no air. Def near the overpipe and header though.
Old 02-26-2018, 09:11 AM   #305
blkdmnd
Maybe not related then.
Old 02-27-2018, 06:55 PM   #306
blkdmnd
Update: I fixed it. It was just a leak because I didn't tighten the inside bolts well enough, and eventually one came off making it worse. Tightened with a crow's foot and extension socket bought at pepboys. Will be going to a friend of mines shop to make sure they're as tight as the others . IF ANYONE HAS THE FLUTTERING NOISE MAKE SURE THOSE BOLTS ARE TIGHT!
The Following 3 Users Say Thank You to blkdmnd For This Useful Post:
Blighty (02-13-2020), Jasten (02-27-2018), Strife26 (02-27-2018)
Old 12-27-2020, 07:33 PM   #307
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Installed mine a few weeks ago. Initially I flashed OFT stg 2+ tune which I used for 600km or so. Then I got a custom tune done by Tomm.brz,[Thanks again]. The car feels noticeably quicker from 2000-5000rpm, and pulls strong to redline.
Video of cold start sitting overnight
A few revs with the car warmed up
Old 02-22-2022, 03:46 PM   #308
NJ-JDM
Drives: 2013 BRZ Limited
Sorry if bumping this thread is a problem. I bought a new to me 2013 BRZ back in Dec. It had a way too loud TRD cat back which I have replaced with a stock system. According to the build/parts list from the ad, it has this header and a Berk catted front pipe. The gasket at the header to over pipe is blown out. What size do I need? Is a stock gasket to small? Or does it need to be bigger? I haven't been able to find much info so far.
Thanks
2013 BRZ Limited
NJ-JDM is offline   Reply With Quote
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 10:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 01:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 08:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
