Old 02-24-2018, 12:15 AM   #1
DeuxLaSole
13 FRS
Covering Trunk Holes w/ Vinyl
Background Info: Currently have monogram spoiler on trunk, looking to switch to the legsport/legstyle spoiler.
As stated in the title of this thread, does anyone have experience with covering the holes remaining from the previous spoiler with vinyl? I was thinking of doing this (with duct tape taped on the inside for support) and then putting the new spoiler on top of the vinyl with the 3M that came in the package so it's covered.
My concerns are:
  • Leaks
  • The vinyl lifting from the 3M pulling on it due to speed
  • Rust
Thanks
-J
DeuxLaSole is offline   Reply With Quote
The Following User Says Thank You to DeuxLaSole For This Useful Post:
fixa (05-04-2018)
Old 02-24-2018, 03:42 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yep. Answered your own question.
It may work for a few days, but eventually the elements will take its take it's toll.
They only way it could work is that you seal up the base of it with sealant or a gasket. But that's assuming the new wing base covers all the holes.
Old 02-24-2018, 01:36 PM   #3
DeuxLaSole
13 FRS
Hmm, I wanted to put rubber gaskets but I don't think the new wing will sit proper. Yeah I confirmed the new wing will cover the holes.
Old 02-24-2018, 04:30 PM   #4
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
My two cents, I had a limited BRZ spoiler on my trunk, took it off, got the trunk wrapped. I put some vinyl on the inside of the holes, never covered it with a spoiler tho. It was fine for over a year and a half, then someone came and poked the holes so they broke the top layer of vinyl, but the pieces on the inside kept any leaks from happening. Never needed to replace them or anything, eventually went CF with the trunk.
MalcolmHimself is offline   Reply With Quote
The Following User Says Thank You to MalcolmHimself For This Useful Post:
DeuxLaSole (02-24-2018)
Old 02-24-2018, 07:20 PM   #5
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I first plugged the holes with plastic plugs like this then wrapped my trunk. Worked OK.
Lunatic is offline   Reply With Quote
Old 02-24-2018, 08:22 PM   #6
DeuxLaSole
13 FRS
Thanks man that gives some good insight on how vinyl can potentially keep leaks out.
Old 02-24-2018, 08:24 PM   #7
DeuxLaSole
13 FRS
This could also be an option but I'm not sure if the new wing will sit flush or sit properly with these installed.
Old 02-25-2018, 01:43 AM   #8
If the spoiler covers the holes and it has 3M tape that goes over or around them then just slap it on over the holes. The 3M tape will act as a gasket and seal it all up with no issues. The more layers you add the more possible points of failure you introduce.
DeuxLaSole (02-26-2018)
Old 02-26-2018, 10:35 AM   #9
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
I did this exact same thing. I took the OEM spoiler off, covered the holes with vinyl on the inside and outside. I ran it wingless for a few months with no problems, then got a TRD style wing and mounted it over the vinyl with 3M tape. 2 years and no issues.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
DeuxLaSole (02-27-2018), DrifterD (02-27-2018)
Old 02-26-2018, 04:24 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I've had a vinyl laminated sticker over a few holes in my trunk for years. It has never leaked.
I LIKE TIRES!
Old 02-26-2018, 05:09 PM   #11
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I have used some plastic plugs that I got from Lowe's that worked fine.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
DeuxLaSole (02-27-2018), Leonardo (02-26-2018)
Old 02-27-2018, 12:18 PM   #12
DeuxLaSole
13 FRS
Sweet, glad to hear that someone has done what I was planning. I'm pretty much just being antsy cause it's warming up here in Canada and my cars at a remote storage so I don't have the availability to fiddle with possible solutions.
Old 02-27-2018, 12:56 PM   #13
DrifterD
Drives: 15' Halo
Did the same exact thing, can confirm.
2015 Halo MT
@denneee
@haroseattle
DrifterD is offline   Reply With Quote
Old 02-27-2018, 06:40 PM   #14
Mazikowski
Drives: 2013 GBS BRZ Limited
{Picture of plug}
If you wind up going this route I would recommend putting a small dab of silicone under the head of the plug so you're sure no water will be getting in under it.
Mazikowski is offline   Reply With Quote
WTB: OEM Trunk w/ no holes or wing iLuveKetchup NY / NJ / CT / PA 1 01-28-2018 06:12 PM
Help covering front bumper license plate holes JLMIAMI Cosmetic Modification (Interior/Exterior/Lighting) 56 01-27-2018 06:39 PM
WTB: FRS trunk without OEM holes RavenFish Want-To-Buy Requests 1 06-03-2016 03:33 AM
FS: OEM Trunk (no holes) MicheleAbbate Exterior Parts (Aero, Lighting, Etc.) 3 05-03-2016 10:03 PM
Recommended OC/LA shop to paint trunk spoiler and fill in trunk holes? tracerit Southern California 13 04-20-2016 01:39 PM
