#2493 |
Drives: 2017 CWP BRZ w/ PP
Went with the non-factory STI ones that were available at the time.
My 2017 JDM tS Build
IG: @TheJonRZ |
| The Following User Says Thank You to JonRZ For This Useful Post: | Sergeb96 (02-23-2018) |
#2494 |
@Veloist / @trippinbillies40 question about this:
![]() Do either of you know if this works with 2017s? Is it the entire housing or just the bulb? Also brightness? And if the part can be purchased separately, if so. To clarify this is taken from the Build a 2018 BRZ page. Looks like a $45 option to have the cabin dome light swapped to LED. |
#2495 |
Drives: 2013 Subaru BRZ Premium MT
#2496 | |
Drives: '14 981CS, '99 NB1
Dude - https://www.diodedynamics.com/dome-l...ubaru-brz.html I've had one of these for over a year in my '17 - works great. No need to look to factory option for that. |
#2497 | ||
Look at my posts in this thread: http://www.ft86club.com/forums/showthread.php?t=125565
Instagram: @spike.grc
#2498 | |
Drives: 93 MR2, 22 GR86, 23 GR Corolla
This is the part number: H461SFL110 And it actually will fit every BRZ from 2013+ The $45 is for a single bulb lol
SPECIAL EDITION VIN LISTS: |
#2499 | |
Geez. I wonder how reliable these are.. 45 is a lot but if it's more reliable than what I've had then it might be worth getting.
#2500 |
Drives: 2015 BRZ
why not try a different type of bulb like the HP6 or SMF6? Tbh i have the SMF2 bulb its decently bright for me and i've had no issue using it in cold weather
#2501 | |
#2502 | |
These are only the larger, inner pieces. You'll need the smaller, outer pieces if you want to complete the look... and since they are also, unexpectedly, piano black (like the interior stereo surround), you'll want to. I didn't need the outer pieces since I have the JDM LEDs, so I'm fine - otherwise they would look awful with the stock flat black outer pieces. I ordered these from my local dealer the day you posted this, and they arrived today. Attached a pic for reference. |
| The Following 2 Users Say Thank You to johan For This Useful Post: | kuczynskika (02-24-2018), SkyeHack (02-23-2018) |
#2503 | |
Drives: 2018 BRZ tS (CBS), AE86 GT-S, MA70
| The Following User Says Thank You to yurikaze For This Useful Post: | SkyeHack (02-23-2018) |
#2504 |
Nope. They are OEM.
The stock 17 flat black bits in this area are in 2 pieces, the outer piece is removed and the LED installs in its place. The tS bit is the same shape. I expect it to fit exactly the same. I think what throws people off about the LEDs is that they look like they exist in the same two dimensional space as the top right of the inner piece. While this is true, they sit outward on the 3rd dimension, over the top of the stock piece. So it's still there, it's just behind a shallow portion of the LED that covers it. Sorry if that's confusing. |
#2505 |
Attached before / after
| The Following 5 Users Say Thank You to johan For This Useful Post: | durtdonthurt (02-24-2018), norcalpb (02-23-2018), SkyeHack (02-23-2018), Veloist (02-23-2018), yurikaze (02-23-2018) |
#2506 | |
Whats the install like for these? Do you have to pull the bumper?
| The Following User Says Thank You to spike021 For This Useful Post: | SkyeHack (02-23-2018) |
| Tags |
| it sucks to be broke, sti omg! |
| WTB: Parts for my FR-S | hyperpunx | Interior Parts (Incl. Lighting) | 1 | 03-05-2013 05:28 PM |
| [Group Deals] SoCal Subaru BRZ parts or Any Parts | Giccin | Southern California | 25 | 08-26-2012 10:30 AM |
