Old 02-23-2018, 01:17 PM   #1
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
PP Brembos: Strange feel under light braking?
I find it difficult to smoothly brake at low speeds with the PP Brembos with the OEM pads. Coming to a stop, there doesn't seem to be much resolution at the end of the pedal to stop without suddenly jerking the car to a halt. If I focus enough, its possible, but certainly more difficult than your average OEM brakes.
Have I incorrectly bedded that pads? Or is it just a characteristic of the brakes themselves?
mistople is offline   Reply With Quote
Old 02-23-2018, 01:58 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
This is not my experience - I've found them almost too progressive, taking effort to stop hard, even moving slowly. I don't have many miles on the setup so I suppose that could change.
At a guess, your technique will improve with practice, where it's about learning subtlety at a foot position you've never needed to care. You might also evaluate seating position, and verify you're able to use small muscle groups to control pressure. I'm not sure these are likely, but figure it's worth throwing it out there.
Old 02-23-2018, 02:39 PM   #3
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
There are variety of factors playing into this. We have setup multiple vehicles that have the PP kit and the Brembo GT. If you have an application on what you will subject your car to, please let us know and we can supply you with the appropriate setup.
CounterSpace Garage is offline   Reply With Quote
Old 02-23-2018, 02:54 PM   #4
mistople
mistople's Avatar
I have no problems (yet) with the brakes under heavy load. As I learn more at the track, I'm sure I'll venture into cylinder braces, upgraded lines, etc. For aggressive backroad/canyon driving, OEM has been mostly OK.
I'm mostly just wondering if other owners of stock PP BRZs have had similar impressions of the OEM setup.
Old 02-23-2018, 02:59 PM   #5
spike021
spike021's Avatar
I don't really have a point of reference aside from this car, but I think I've somewhat experienced this as well with mine.
Like @cjd said, it's good to learn how to apply pressure with the small muscles on the bottom of your foot if possible. But I do think I've noticed sometimes the bite of the brake is a bit more noticeable than expected. I think now that I've driven the car about a year though, most of the time I'm able to control the brakes fairly well so I don't notice this.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 02-23-2018, 03:02 PM   #6
CounterSpace Garage
It is a misconception that MCB and SS braided lines will suddenly improve that brake response. The OEM brake pads are formulated for excellent daily and public road usage. For track and more aggressive use, there are categories of pads available in stock. Let us know when you're ready for a consultation!
Old 02-23-2018, 03:11 PM   #7
mistople
mistople's Avatar
Sorry, I should have been more clear. I meant that I have none of the usual problems owners talk about in regards to the standard setup--firewall flex, loss of feel over time, etc. I'll probably address those with the mods above as needed once I start tracking.
I'm more concerned with the feel of the brakes when just puttering around town. They are fine under aggressive driving situations, but feel very binary at lower speeds.
Old 02-23-2018, 09:25 PM   #8
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I think mine feel the same way mistople. It's not abnormal. In fact, even the Evo X Brembo brakes felt kind of like that. It's almost a sticky feeling. I ordered some Endless pads and fluid so we'll see how that changes things.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following User Says Thank You to Bristecom For This Useful Post:
mistople (02-23-2018)
Old 02-26-2018, 01:17 PM   #9
CounterSpace Garage
We can certainly help you out when the time comes as we have a fairly extensive resume testing a variety of brake setups and compounds.
Old 02-26-2018, 01:57 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
CounterSpace Garage: i sometimes wish for unified cross vendors pads temp/Mu chart to exist. Have you ever considered making such or it's not possible to make w/o some highly specialized (& probably thus very expensive) brake test rig/dyno?
Old 02-26-2018, 02:29 PM   #11
R2
Even a comparison chart drawn subjectively by someone with reliable experience would help.
R2 is offline   Reply With Quote
Strange steering feel speedyspaghetti Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-13-2017 09:47 PM
Traction light flashing under trail braking; TC and VSC are both off... CSG Mike Tracking / Autocross / HPDE / Drifting 72 06-12-2016 08:18 AM
How to fix light feel with the clutch pedal? hot86lova Scion FR-S / Toyota 86 GT86 General Forum 8 08-04-2014 01:06 AM
Aftermarket Reverse light with triple flash on braking? Bonks86 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-19-2013 10:03 AM
Light flashing under trail braking. CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-16-2012 04:10 PM
