Old 02-22-2018, 09:24 PM   #29
Agree.
You happen to pick a car in the fastest color too.
Nah. The blue pigment weighs .002 grams more.
Old 02-22-2018, 09:27 PM   #30
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I thought it was the metallic flake.
Tcoat (02-22-2018)
Old 02-22-2018, 09:27 PM   #31
Originally Posted by tzhu07 View Post
It looks like you're not using the default factory bracket, since that one intersects both the bumper and grill. So what bracket do you use?
I really don't remember, but I'm pretty sure the black, plastic bracket that I used, came with the car (2013 FR-S). I just screwed it into the grill .....
(and NO, my car has never overheated, however, I have never tracked it)
Old 02-22-2018, 09:38 PM   #32
Sapphireho
Famous Potatoes
Sapphireho's Avatar
BS.
humfrz (02-22-2018)
Old 02-22-2018, 09:41 PM   #33
Originally Posted by OND View Post
Why do you guys hate engine cooling so much?
Because, like me, as my car ages, it likes to be warmer .......
Impureclient (02-22-2018)
Old 02-22-2018, 09:58 PM   #34
Brink
Drives: 2017 BRZ
Am I the only one who actually prefers the asymmetric look of the Grimmspeed bracket to the center-mounted position? Not even taking into account the engine cooling, drilling or not, etc. just looking at positioning.
Brink is offline   Reply With Quote
Old 02-22-2018, 09:58 PM   #35
BS.
Well, OK, you got me there, maybe a flat track race or two ...... back in the day ......
* milled head
* straight header
* built engine
* aluminum drive pulley
* HD brake pad
* sloped front for aero
* staggered wheels
* continuously variable transmission (CVT)
Old 02-22-2018, 10:04 PM   #36
Sapphireho
Famous Potatoes
Sapphireho's Avatar
* milled head
* straight header
* built engine
* HD brake pad
* staggered wheels
Is that a Cat-O-Lak?
humfrz (02-22-2018)
Old 02-22-2018, 11:30 PM   #37
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I don't get the off-center mounting for looks. I see one, "looks stupid". Worried about cooling? Drill holes in the plate, at least that would look cool. That decal plate is a good idea. I don't see why a low-key number set up front would need to be that big, I've yet to get a ticket running from a cop in reverse.
PetrolioBenzina is offline   Reply With Quote
Old 02-23-2018, 12:58 AM   #38
Brink
Drives: 2017 BRZ
Any car can mount their front plate in the center of the bumper/grille. Only racecars get to mount it off to one side on the tow hook. There are plenty of non-twin cars that try to get away with the look by drilling the front plate into some part of the bumper off to one side without actually being on the tow hook but these always look like garbage. Tow hook mount is the way to go.
Old 02-23-2018, 01:18 AM   #39
PetrolioBenzina
Drives: 17 86
Madness. The asymmetric drag just destroys tires.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Tcoat (02-23-2018)
Old 02-23-2018, 08:05 AM   #40
DarkSunrise
DarkSunrise's Avatar
@Tcoat is right. On the street, there's no noticeable difference in coolant temps with the front plate mounted that way.
From what I've seen in my data logs, the bigger concern is actually overcooling the oil on the street with an air-liquid style cooler (even with a thermostat controlling the flow). That's where using the license plate as a block-off helps.
2022 BRZ Build
2013 FR-S Build
Old 02-23-2018, 08:13 AM   #41
akapero
akapero's Avatar
Drives: 860SE
I much prefer the tow-hook mount. A plate looks out of place on the front of any car, but I'm not drilling into my car to put one on, nor do I like the zip-tie option. The tow-hook mount is the least offensive of my options.
akapero is offline   Reply With Quote
Old 02-23-2018, 09:21 AM   #42
Nah plates don't look out of place on the front of cars. They have been there for about 90 years so why all of a sudden do they look wrong? This whole "the plate in the center looks bad and off to the side is cool" thing is a relatively new fad.
At least the angled rear plate fad didn't last long.
Edit: LOL and I just noticed the 1 1/4" exhaust on that road warrior! Must sound awesome.
humfrz (02-23-2018)
Help Removing Front License Plate Bracket immaculate Cosmetic Modification (Interior/Exterior/Lighting) 23 05-08-2018 05:09 PM
Front License Plate Bracket mervingee BRZ First-Gen (2012+) — General Topics 22 07-03-2014 09:43 AM
Front License Plate Solution? Dillano609 Scion FR-S / Toyota 86 GT86 General Forum 72 03-16-2013 02:00 AM
Frs Cap and OEM Subaru Front license plate bracket Xdragonxb0i Miscellaneous 1 01-16-2013 12:25 AM
My Front Plate Solution Flat Black VW BRZ First-Gen (2012+) — General Topics 55 11-06-2012 09:07 AM
