Old 02-22-2018, 10:22 AM   #29
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
Originally Posted by rcm47 View Post
@Shneegle thanks, that looks great! So this was just springs, camber bolts, and adjustable rear LCAs?
Thanks, and correct. It has been changed since then but at the time of those photos that's what it was.
Originally Posted by kpamir View Post
I recently moved and have to raise my car a bit, I am on HSD coils and they have unfortunately seized up hard.
My cheapest option is to put the stock struts in, but I do want that slight drop so Ill be getting the trd lowering springs.
I am running rpf1 17x9 +35 on 245/40/17 mpss. I am seeing that a couple of the guys here have that set up and it works fine with the 1" drop from the trd lowering springs.
Just to confirm before i make the purchase are the camber bolts necessary for the fitment ? Or was that installed because you wanted that slight tuck in for the wheels?
Thanks!
Autox/track is why I had them in. I wanted closer to -3 degree of camber in the front but without top-hats you can get that. The camber was bringing the wheel/tires closer to the shock/spring. No the bolts are not necessary for the fitment. The tops of the tires/wheel might poke a little more tho.
Shneegle is offline   Reply With Quote
Old 02-22-2018, 10:53 AM   #30
kpamir
Drives: 2015 halo white fr-s
Yeah they do poke a bit, I had the wheels on stock for a bit before getting the HSDs. But I can live with that if I can get into my garage haha.
Thanks for the confirmation dude.
kpamir is offline   Reply With Quote
Old 02-22-2018, 02:05 PM   #31
DarkSideFRS
Drives: 2013 pearl white FR-S
u'll be fine.. i have 17x9 57DR +38 lowered on TRD springs with -1.7 camber up front and i pretty close to the perch... with +35, u'll have tons of space
DarkSideFRS is offline   Reply With Quote
Old 02-25-2018, 08:25 PM   #32
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I've tracked with 245/40/17 on RPF1 17x9 +35 and got zero rubbing at all.
Pic below shows the wheel/coilover under heavy compression.
Wise is offline   Reply With Quote
Old 02-25-2018, 10:45 PM   #33
carlovestela
Drives: 2015 Firestorm FRS
Hows the performance on 17 9 with 245/40 tires?
It got slower?
carlovestela is offline   Reply With Quote
fitment, offset, rubbing, tires, wheels
17x9.5 +15 fitment Matty-T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 05-02-2015 06:26 AM
17x9 6UL - FT86 fitment available soon Guillaume Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 02-17-2015 11:54 AM
RPF1 Fitment pf330ci Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-25-2014 10:07 PM
used RPF1 17x9 +35 or new Rota RT5 17x9 +42 Roadcone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-12-2014 01:16 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
