#43 |
Drives: 2JZ FRS
I have repaired damage like this on a ton of doors, of all makes. something pressed against the door skin and the sheet metal formed around the crash bar, which is part of the door frame structure and foam glued to the door skin. The only time I have seen the door skin show the line of the crash bar from temperature change is when a body shop replaced the door skin and used a non flexible adhesive between the crash bar and skin
#44 | |
Not disputing just don't see how it gets bigger.
#45 |
Drives: 2JZ FRS
A picture of the foam would make it a little clearer to see if there is a material problem which would allow a temp change to make the line change. it takes a minimal bump to make a crease around the bar. Can be easily done without leaving any mark whatsoever on the paint.
| The Following User Says Thank You to spitfire481 For This Useful Post: | Tcoat (02-21-2018) |
#46 | |
So, what is the "fix" ..?? humfrz |
#47 |
Drives: 2JZ FRS
figure out if its from an impact, or a material failure from the factory (foam adhesive) first
#48 |
A Nobody
Drives: FRS
interesting, being from the same city as OP i sure hope i dont find myself anywhere near him lol i like my doors the way they are
#49 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Looks like the drivers side?
Has a snowplow been past and piled a load against it?
"I gotta rock." -- Charley Brown |
#50 |
Drives: FR-S, XJS, C10
I have it in the shop now. Many years ago they performed the window freeze fix. Could that be related?
#51 |
#52 |
| The Following User Says Thank You to Rustyspoon For This Useful Post: | JustSomeGuy (02-21-2018) |
#53 |
Don't see how.
#54 |
A Nobody
Drives: FRS
#55 |
ZWEI KOLBEN
Drives: 2017 86 Halo 6MT
I once hauled a motorcycle in a Tacoma and the rear tire of the motorcycle was resting on the truck's tailgate. The tailgate did not sag or bend and the gaps and function were still perfect after the trip. That said I did have a slight protruding crease similar to this. I assumed there was enough flex in the tailgate to let the internal support come in contact with the backside of the skin.
| The Following User Says Thank You to SCQTT For This Useful Post: | Tcoat (02-21-2018) |
#56 |
Drives: subaru brz
Can you back the pics off a bit so we can tell what we are even looking at?
| WTB BRZ Driver's Side Door, WRB | ngabdala | Cars for Sale/Trade | 1 | 06-17-2015 10:18 PM |
| WTB BRZ Driver's Side Door, WRB | ngabdala | NY / NJ / CT / PA | 0 | 06-16-2015 06:17 PM |
| WTB BRZ Driver's Side Door, WRB | ngabdala | New England | 0 | 06-16-2015 06:16 PM |
| WTB BRZ Driver's Side Door, WRB | ngabdala | Want-To-Buy Requests | 0 | 06-16-2015 06:12 PM |
| Driver-side door not responding ! | Pish | Issues | Warranty | Recalls / TSB | 10 | 01-21-2015 12:42 PM |
