Old 05-23-2014, 10:36 PM   #15
CSG Mike
CSG Mike's Avatar
Your diff is on it's way
dp1 (05-23-2014)
Old 12-18-2016, 06:56 PM   #16
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by dp1 View Post
Just talked to EFI and they will order carrier bearings, axle seals and pinion seal to have on standby if we need them, then return if we don't - great approach.
I talked to DSS re axle, and both they and EFI mentioned it's unlikely it got damaged due to design. Clip can be retrieved with a magnet if it's still inside when axle is pulled out. DSS is sending spare clips now to have ready for Tuesday at @PrimeMotoring.
This should get sorted out on Tuesday.
Looks like i have the same problem. I have dss axles and kaaz 1.5way diff.
BRZ RN is offline   Reply With Quote
Old 12-19-2016, 11:34 AM   #17
wparsons
wparsons's Avatar
I'm taking the car to Scion tomorrow morning to have this checked out. The fluid was changed to Motul by @PrimeMotoring at around 11k miles. Was looking at OSGiken but now I see the "manual transmission only"...Cusco would be my other top choice but I need to research best AT diff options some more. Will follow break in procedures to the letter.
Thanks!
As far as I know, the stock diff is identical between AT and MT, I can't see a single reason why an aftermarket one would be transmission specific.
In a FWD gearbox, I can totally see that. Probably a copy/paste error more than hard requirement.
flickr
Old 12-21-2016, 05:37 PM   #18
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
Its just typical Japanese coverage of application. The product was developed around the manual transmission differential.
For instance, the ND manual gearbox differential is significantly sized differently than the automatic. Its safer to clarify what the unit was designed around than for a customer to find out the hard way.
oinojo is offline   Reply With Quote
Old 12-21-2016, 06:31 PM   #19
JoeC
Drives: Subaru BRZ Limited
Originally Posted by subielife View Post
I was driving his car when it started leaking. Got it into the air after the session and the drain bolt was loose, atleast 1/2 turn until tight again. Then I opened the fill hole and a good amount of fluid drained. Not normal, and a few of us agreed it was overfilled.
my car did the same thing after its first track day. I took it into the dealer for documentation and evaluation. They drained the fluid and concluded that there was no crush washer installed. Must have been that way from the factory because I'd never had it off. definitely strange though.
JoeC is offline   Reply With Quote
Old 02-06-2018, 07:34 PM   #20
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Did you ever determine the cause if the circlip failure?
Surok is offline   Reply With Quote
Old 02-08-2018, 09:37 PM   #21
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
I am having the same issue, but what is causing the axle to move in and out anyway? my circlips arent broken. i have tried 3.
for me its the right axle only. i replaced the diff with a new one and its still happening. the axle goes in just fine and clips in, but after a short drive it has popped loose again. DSS 600HP axles.
Old 02-20-2018, 08:56 PM   #22
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
an update for this.
i emailed photos of my axle to driveshaft shop and they agreed that they will replace the inner shaft that goes into the diff for me. i tried a new DSS 600Hp axle and now the car is perfect
Old 03-19-2019, 03:49 AM   #23
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by Surok View Post
an update for this.
If you don't mind... what was the issue with the inner shaft? I have been plagued with this same issue of axle leaking/popping out for 2 years now.
Old 03-19-2019, 05:03 AM   #24
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
I just went back to oem.
Old 04-16-2019, 02:16 AM   #25
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
i dont know what was the issue, and i actually just deleted the photos last night. but they sent me a new one for free. i got it put in, and all was right with the world.
Old 09-29-2019, 12:03 AM   #26
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Diff was leaking fluid from both axles. There was some play in both axles where I could slide them in and out. I took out the diff and it looks like maybe the clips for both axles are broken? I'm not sure, but the clips have a pretty good gap. Does this look broken to anyone?
https://photos.app.goo.gl/WL2C7e1BoEMFs4r19
I'm having trouble embedding an image from my phone. If the link doesn't work work I'll try something else.
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
OSGiken vs. KAAZ Super Q LSD FutureFT86 Engine, Exhaust, Transmission 11 03-29-2017 06:36 AM
FS: 2013 BRZ Limited | Random interior bits from track build DatApex Interior Parts (Incl. Lighting) 28 09-08-2014 03:49 PM
JRZ, Cusco, Tomei, Moonface, HKS, Volks, and OSgiken, UPDATE 2/23/14 Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 04-01-2014 12:47 AM
When to replace street tires used for the track? ayau Tracking / Autocross / HPDE / Drifting 4 07-23-2013 12:45 PM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 12:26 PM
