| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
JRZ, Cusco, Tomei, Moonface, HKS, Volks, and OSgiken, UPDATE 2/23/14
Evasive Motorsports Service For Customers
Our philosophy at @Evasive Motorsports is minimizing track times by improving the handling and aerodynamics on the FR-S/BRZ. But the biggest part having a balance car is the suspension, brakes, aero, wheels and tires. The combination of the suspension and aero components allows the car to be consistent at the track with better handling Installing JRZ Pro Coilover Systems Cusco Lower Control Arm Moonface Roll Centers Front Bridgestone RE-11 RT TE37 17x9.5 +40 Square Project Mu Club Racers HKS Oil Cooler OS Giken Diff Final Drive Tomei Exhaust System ![]() RT TE37 17x9.5 +40 Square with Bridgestone RE-11 ![]() ![]() JRZ RS Pro Coilover The RS Pro damper allows for external adjustment of both the rebound and compression functions of the damper. In addition to the same precise and accurate rebound adjustment as in the single adjustable race damper, the RS Pro are double adjustable. The compression adjustment technology is the same as that of the race version. The RS does not utilize a separate canister. The RS Pro has both the rebound and compression adjustments on the damper itself. The RS Pro takes the RS one step further with the addition of an external reservior canister. The RS Pro utilizes the external reservior to house the precise compression adjustment mechanism. (JRZ Pro with Hyper Co Springs) ![]() ![]() JRZ Reservior allow easy adjustments with out laying on the floor at the track! ![]() Mounted JRZ Reservior to the Cusco Rear Strut Bar for clean and easy access! ![]() Custom Alignment Specs (Evasive Specs) Done on our own Hunter Alignment Machine. [IMG]http://img.photobucket.com/albums/v693/Randizzle8/photo2_zps5ad7b***.jpg[/IMG] ![]() UPDATE 10-30-13 We just finished adding a HKS oil cooler for the temps at the track. ![]() ![]() UPDATE 2-23-14 Adding a new OS Giken rear differential and final drive will better help with the lack of power for this car. We are also using the new Cusco differential cover to keep the diff cooler! This will help by not having to change fluids ever so often. For the install you will need to replace the bearings, seals, and shims so the teeth can make perfect contact. ![]() ![]() ![]()
CAMBAM
Drives: '13 Whiteout FRS
Why didnt you tag these photos inappropriate for work??? This is obviously Car Porn
If you think the FRS/BRZ isn't fast enough, the roads you're driving on are too straight.
I like to eat!
I agree. Car porn at it's best!
![]() ![]() ![]() ![]() ![]() My car's loaded with blue stuff underneath, but these parts..............................ooooooh |
Drives: 1985 P-Type
Oh man I bet those JRZ feel great.
Ninja edit: I love that it still has the dealer plate. Brand new! |
Drives: Turbo BRZ & Supercharged E90 M3
sick!
Drives: BMW E84
Nice wheels!
Drives: Asphalt FRS
My god...I would just drive around with the trunk open all day. So beautiful
Drives: 1985 P-Type
#10 |
#11 |
#12 |
Drives: 2015 Trailhawk
#13 |
#14 |
Just Added a new HKS oil cooler!
| Tags |
| evasive, evasive motorsports, jrz, moonface, te37rt |
| Rogue Motorsports U.K. Rocking Evasive Motorsports GT AERO! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 65 | 12-05-2014 03:22 PM |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 12:17 PM |
| Evasive Motorsports now offering Dyno/Ecu Tuning Service | Evasive Motorsports | Southern California | 9 | 12-19-2012 09:58 PM |
| **EVASIVE MOTORSPORTS CUSCO** | Evasive Motorsports | Brakes, Suspension, Chassis | 18 | 11-21-2012 06:15 PM |
| Seeing what this car can do! Evasive Motorsports! | Evasive Motorsports | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-31-2012 02:40 AM |
