Old 02-19-2018, 08:26 PM   #1
Andyxin
Drives: 2017 BRZ WR blue PP
Ohlins updated it's R&T coil-over for our car
https://world.ohlins.com/app/uploads...Subaru_BRZ.pdf
Ohlins didn't change the spring rate and says confidently that 4K 3K spring rate is a great setup. I wonder what's the differences between the new one and the old one. Maybe more shock travel?
Andyxin is offline   Reply With Quote
The Following User Says Thank You to Andyxin For This Useful Post:
nikitopo (02-20-2018)
Old 02-19-2018, 08:32 PM   #2
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
I found this a few weeks ago when I was trying to order the spacers I lost for the top mounts and endlinks... the manual is a lot more detailed for the SUS MP21 vs the SUS MP20, and actually lists part numbers! Unfortunately, part numbers for all the spacers were “bad” and could not be ordered. Jake from Ohlins USA said he was trying to get a package available to just order all the little bits and pieces that come with the Road and Track kit.
Also the MP21 comes with rubber spring seats.
idkwhatimdoing is offline   Reply With Quote
The Following User Says Thank You to idkwhatimdoing For This Useful Post:
Old 02-19-2018, 08:41 PM   #3
idkwhatimdoing
Evidently the MP21 is TUV approved as well, MP20 is not
Old 02-20-2018, 12:53 PM   #4
Andyxin
Maybe MP21 is for passing the TUV rules lol
Old 02-20-2018, 01:37 PM   #5
jamal
jamal's Avatar
Drives: Legacy GT
Wait, 4k/3k, for real?
Not the only coilover mfg that puts softer than stock rates on their stuff or the completely wrong balance. Or wait, most of them do one of those things.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
wparsons (11-13-2018)
Old 02-20-2018, 03:21 PM   #6
idkwhatimdoing
I am running the MP20 currently and I have to say the spring rates are very well matched to the car.
Stiffer doesn’t really mean better.
The Following 3 Users Say Thank You to idkwhatimdoing For This Useful Post:
DAEMANO (02-20-2018), nikitopo (02-20-2018), Tokay444 (02-21-2018)
Old 02-20-2018, 04:05 PM   #7
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There were some posts about a knocking noise. Maybe the rubber spring seats solve this issue.
http://www.ft86club.com/forums/showthread.php?t=110228
Old 02-20-2018, 04:19 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
idkwhatimdoing: well matched with stock or not much different from stock grip level tires. Doubtful those rates matching that well with much grippier tires many trackday enthusiasts running.
Old 02-20-2018, 04:29 PM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
4kg/mm front with 3 kg/mm rear doesn't really add up considering 0.95 front and 0.75 rear motion ratios. Wheel rates are ~3.6 kg/mm front and ~1.7 kg/mm rear, more than twice as stiff up front. Seems out of whack for a 54/46 F/R car with very modest power/weight...
Old 02-20-2018, 05:24 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
This seems to be a common thought on this forum. FWIW, when I was on stock suspension and BFG R1Ss, my lap times were faster than T2s with Maxxis RC1s.
I'm not saying R1Ss are a great match for an otherwise stock car, but I really don't think the "matching" of the tires with suspension is as big of an issue as what most people here seem to think.
In the end, sticky tires = speed.
The Following 3 Users Say Thank You to Pat For This Useful Post:
DAEMANO (02-21-2018), idkwhatimdoing (02-20-2018), strat61caster (02-20-2018)
Old 02-20-2018, 05:43 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Pat: one CAN go on sticky tires and soft springs. It's just for that being far from best possible suspension setup. Sticky tires+soft springs=car rides on bumpstops. It drives, and grippy tires do grip, but how well dampening on bottomed out coilovers to bumpstops is, and especially if there happens to be rough surface or you are going over kerb.. Also for some too much roll may reduce confidence in pushing more in turns. It's subjective handling feel though, as grip is still there.
Somehow most common contra-question for "which coilovers" i've seen - "what tires".
Old 02-20-2018, 06:15 PM   #12
idkwhatimdoing
I have taken speed “humps” at 30mph on these shocks with stock wheels and I’ve never hit the bump stops once, although I’m running the Raceseng 2 inchers on the rear.
I think one must be more open-minded to soft spring rates.
Old 02-20-2018, 06:23 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
stock wheels? assuming probably also limited-grip stock primacies? Due which they may loose grip prior coilovers bottom out. Now take wider and much grippier compound half slicks & slicks, and it's easy ride on bumpstops almost every track curve before they'll loose grip.
I haven't denied that these might be very well matched to stock tires or when normally daily driving on public roads, both comfort & handling wise. Not so much for tires with lot of grip & on track. As in - way less 'track' in 'road & track' vs stiffer original MI20 R&T.
Old 02-20-2018, 06:33 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
threads like this make me wish I can repurchase my old Ohlins to keep around for fun.
My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! kkman User/Vendor/Sponsor Reviews, Feedback, Comments 18 03-31-2016 10:59 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
Trailer | Ohlins Install | Interviews With Essex & Ohlins Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 12-24-2013 03:01 PM
