Drives: 2013 WRB BRZ 6MT
Oil leak on front cam seal?
I was looking at the pics the shop took while my BRZ was getting repaired and I noticed that one of my cam-end-covers (?) is darker than the other three, looks like there is some oil leaking in that area. Has anyone else had issues in that arear? Or on one of the other ones?
#2 |
Drives: 2013 Scion FR-S Toyota 86
Pretty common issue. Had my car get fix under warranty. It has TSB for it for oil leak in few areas.
#3 |
Yes, all too common place for an oil leak.
Why was your car in the shop .. ?? humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | MRCA1ST (02-20-2018) |
#4 | |
Here is the TSB for the most common. http://www.ft86club.com/forums/attac...1&d=1413834741
#5 | ||
http://www.ft86club.com/forums/showthread.php?t=124869 Quote:
Cool, thanks guys, I will check it out. I took a look at it and it seems pretty light, there is nothing on the under panel and nothing is actually wet. |
| The Following User Says Thank You to MRCA1ST For This Useful Post: | humfrz (02-20-2018) |
#6 | |
#7 |
#8 |
Oh ya for sure if still in warranty.
#9 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Yeah, that's what I'm doing. Mine is leaking same place as OP as well as the passenger side cam cover I think. Cleaned it all up and paying more attention to oil consumption to figure out how bad it really is. |
#10 | |
![]() humfrz |
#11 |
Mine is a late MY13, sold June 29, 2013 and only had 3k on it when I bought it in January 2016...so I still have some left it was there before all of that (grimy dirty buildup), I just hadn't noticed since it isn't dripping down on anything. And nothing got pushed back into the front of the engine, the engine sits so low in these things it stayed under the affected area. My Perrin tube did get cut by my top pulley/belt, but there's barely any clearance there to begin with. |
#12 | |
![]() humfrz |
#13 | |
Tape into place. Change once per month. There ya go! humfrz |
#14 |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Second time crank seal leak possible crank walk | kiichiro | Engine, Exhaust, Transmission | 13 | 09-19-2018 05:57 AM |
| Auto FR-S - Oil Leak - Front Left of Engine | iPlayDrums | Issues | Warranty | Recalls / TSB | 12 | 03-16-2018 11:48 PM |
| oil leak, drivers side, front of engine | carbonBLUE | Issues | Warranty | Recalls / TSB | 41 | 10-02-2015 11:51 PM |
| Oil leak problem, possible seal issue from repair? | tintumz22 | Issues | Warranty | Recalls / TSB | 12 | 04-02-2015 12:56 PM |
