#29 | |
Drives: Toyota GT86
But it's off topic for AVCS. You can see more here: http://www.ft86club.com/forums/showthread.php?t=119535
#30 |
Drives: FR-S Whiteout
So I started to play with my ACVS a bit to see what I get with Kodename47's cam/VE tool. I have not converted anything to Vdyno since were still pumping winter blend fuel over here.
Here is a bit of the initial logs plugged into the program.. How the heck do I determine which squiggly line is better? LMAO Input appreciated sirs. I suppose I'd still need to do some Vdyno or real dyno pulls to see what it's really doing. (VVT1 intake VVT2 exhaust)
Intent > Content
cowardice is the mother of cruelty. |
#31 |
Drives: Toyota GT86
Nice to see someone else taking the plunge.
![]() Make bigger changes in both directions, then it might be easier to see a trend. Maybe 3 cams something like this (very rough drawing, but you get the idea): ![]() If you input two cams with like 2 deg difference you will have a hard time seeing a difference. If you check out my post 10, you can see how much I moved my curve up and down. My advantage was I was pretty sure I started out with the right shape. At low rpm it was difficult to see much difference, most evident was above maybe 5000 rpm where I had 4 deg difference between the curves. Also I would suggest to change one cam at a time. Leaning back from the screen and squezing my eyes, I would say more exhaust retard below 3500 rpm trends higher - very scientifically. Vgi was updating the tool, I'm not sure if he finished or is still working on it. Check out if there is a new version or try shooting him a PM.
| The Following User Says Thank You to Tor For This Useful Post: | solidONE (02-12-2018) |
#32 | |
Drives: UK GT86
As per previous posts, adjust the intake cam only and see where that gets you as the gains will be more obvious.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | solidONE (02-12-2018) |
#33 |
What base map are you starting from before making the AVCS changes? I'm on the OFT OTS UEL E85 map (plus many tweaks for the forum) and notice they keep the same AVCS settings for both 91 or E85. I'm using the Gruppe-S header and am willing to log and contribute to finding optimal settings for this header.
#34 | |
Drives: Toyota GT86
![]() There is no difference betweem 91 and E85 in with regards to valve timing. It's flow specific. Below in copy paste friendly format (maybe I did some tweaks since the picture above, can't remember anymore). I would much appreciate feedback either as a comment here in this thread or per PM. Intake: Code:
[Table3D] 0.15000000596046448 0.20000000298023224 0.30000001192092896 0.4000000059604645 0.5 0.6000000238418579 0.699999988079071 0.800000011920929 0.8500000238418579 0.8999999761581421 0.949999988079071 1.0 1.100000023841858 1.2000000476837158 1.2999999523162842 1.399999976158142 800.0 0.0 0.0 0.0 0.0 0.0 0.0 10.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 1000.0 0.0 -5.0 -5.0 -5.0 -5.0 0.0 10.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 1200.0 0.0 -10.0 -10.0 -10.0 -10.0 -10.0 10.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 1600.0 0.0 -10.0 0.0 0.0 0.0 0.0 10.0 20.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 2000.0 0.0 0.0 0.0 0.0 0.0 0.0 10.0 20.0 30.0 30.0 30.0 30.0 30.0 30.0 30.0 30.0 2200.0 5.0 5.0 15.0 5.0 5.0 5.0 10.0 20.0 33.0 33.0 33.0 33.0 33.0 33.0 33.0 33.0 2400.0 10.0 10.0 20.0 10.0 10.0 10.0 10.0 20.0 33.0 35.0 35.0 35.0 35.0 35.0 35.0 35.0 2800.0 10.0 10.0 15.0 10.0 10.0 10.0 10.0 20.0 33.0 37.0 37.0 37.0 37.0 37.0 37.0 37.0 3200.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 3600.0 10.0 10.0 10.0 20.0 20.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 3800.0 10.0 10.0 10.0 20.0 20.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 4000.0 10.0 10.0 10.0 20.0 20.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 4200.0 10.0 10.0 10.0 20.0 20.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 4400.0 10.0 10.0 10.0 20.0 20.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 4600.0 10.0 10.0 10.0 15.0 15.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 4800.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 25.0 33.0 39.0 39.0 39.0 39.0 39.0 39.0 39.0 5200.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 25.0 33.0 38.0 38.0 38.0 38.0 38.0 38.0 38.0 5600.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 25.0 33.0 37.0 37.0 37.0 37.0 37.0 37.0 37.0 6000.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 23.0 30.0 34.0 34.0 34.0 34.0 34.0 34.0 34.0 6400.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 20.0 29.0 29.0 29.0 29.0 29.0 29.0 29.0 29.0 6800.0 10.0 10.0 10.0 10.0 10.0 20.0 20.0 20.0 23.0 23.0 23.0 23.0 23.0 23.0 23.0 23.0 7000.0 10.0 10.0 10.0 10.0 10.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 7200.0 10.0 10.0 10.0 10.0 10.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 14.0 7400.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 6.0 6.0 6.0 6.0 6.0 6.0 6.0 Code:
[Table3D] 0.15000000596046448 0.20000000298023224 0.30000001192092896 0.4000000059604645 0.5 0.6000000238418579 0.699999988079071 0.800000011920929 0.8500000238418579 0.8999999761581421 0.949999988079071 1.0 1.100000023841858 1.2000000476837158 1.2999999523162842 1.399999976158142 800.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1000.0 0.0 0.0 0.0 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 10.000610376140001 1200.0 0.0 0.0 10.000610376140001 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 19.99969487337 1600.0 10.000610376140001 19.99969487337 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 2000.0 10.000610376140001 19.99969487337 30.000305249510003 39.99938974674 39.99938974674 39.99938974674 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 2200.0 10.000610376140001 19.99969487337 30.000305249510003 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 2400.0 10.000610376140001 19.99969487337 30.000305249510003 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 2800.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 3200.0 19.99969487337 30.000305249510003 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 3600.0 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 3800.0 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 4000.0 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 4200.0 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 39.99938974674 4400.0 19.99969487337 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 35.00061043758 37.50000009216 37.50000009216 37.50000009216 37.50000009216 37.50000009216 37.50000009216 37.50000009216 37.50000009216 4600.0 19.99969487337 30.000305249510003 35.00061043758 35.00061043758 35.00061043758 30.000305249510003 30.000305249510003 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 35.00061043758 4800.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 32.00073250052 32.49969490409 32.49969490409 32.49969490409 32.49969490409 32.49969490409 32.49969490409 32.49969490409 32.49969490409 5200.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 30.000305249510003 5600.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 6000.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 27.49938971602 6400.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 6800.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 7000.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 30.000305249510003 30.000305249510003 30.000305249510003 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 7200.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 28.99932868455 28.99932868455 28.99932868455 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 7400.0 19.99969487337 30.000305249510003 35.00061043758 39.99938974674 39.99938974674 28.99932868455 28.99932868455 28.99932868455 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144 25.00000006144
| The Following User Says Thank You to Tor For This Useful Post: | Vin (02-12-2018) |
#35 | ||
Smoothing! 2vs2 ![]() 1vs1 ![]() Still need to squint my eyes and lean pretty far back to make out any notable difference. Much easier with the smoothing than without, though. I really want to target the low rpm dead spot I have before the surge of torque. I think you can imagine where it is simply looking at the output of these logs. (3200-3800 rpm)
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 02-13-2018 at 06:34 PM. |
#36 |
Drives: UK GT86
Why not just increase the intake advance in that area to max and see what happens? You have a dip in torque as the cam comes away from max advance..... just saying
.: Stealth 86 :.
#37 | |
I did do a map with -5* from baseline and it was noticeably less power and it was reflected in the graphs using your tool. EDIT: Red = Retard Yellow = baseline blue = adv1 green = adv2 ![]() A definite improvement from 3600 to 4100rpm with the intake advance increased from baseline. But it looks like the dip was shifted over 500rpm or so. Opposite is true with intake cam retarded slightly from baseline. I think I can get it a bit better with a bit more tweaking.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 02-16-2018 at 01:26 AM. |
#38 |
Drives: Subaru BRZ
Out of topic, how can you make those virtual dyno plots? i tried couple of logs but i couldn't
![]() i have the virtual dyno software, even i try to import some logs to it, i got some different error messages. Is there any trick to apply the logs in order to use in virtual dyno? |
#39 | |
Drives: UK GT86
.: Stealth 86 :.
#40 |
Drives: Subaru BRZ
#41 | |
http://www.ft86club.com/forums/showthread.php?t=59743 https://www.evolutionm.net/forums/ev...-properly.html
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | halujeddo (02-17-2018) |
#42 |
Did some logging after reverting to the baseline exhaust timing with the adv2 intake and this was the result. Doesn't seems very realistic that its running that much better. Maybe the application doesnt take into account IAT or ambient temp differences? Although they were all within 5*f in terms of IAT difference. What do you think @Kodename47 ?
Red and blue trace: most recent iteration for valve timing maps "adv2" intake map(with baseline exhaust) Green: Previous map "adv2" intake map with exhaust more retarded than baseline Yellow: Baseline exhaust with adv1 (slightly advanced intake cam) ![]() EDIT: Okay I think I know what is causing the discrepancy.. On the newest map I also modified the MAf scale very slightly (+3% from about 3.0-4.0 maf voltages) because it was running a bit too lean on this winter blend petrol. The increase in VE must be about 3% from before because the maf values increase 3%... my bad. lol edit 2: MAf Scale corrected results. Not much of a difference.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 02-21-2018 at 02:12 PM. |
| AVCS tuning | Turdinator | Software Tuning | 9 | 11-24-2015 01:31 PM |
| AVCS tuning for power and economy | KoolBRZ | Software Tuning | 8 | 04-13-2015 11:07 AM |
| Feeler: Dyno Tuning Session via Jamesm @ HRI tuning | sw20kosh | Northern California | 27 | 11-28-2014 07:53 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Dyno Nights @ FR&R tuning | GeeTee86 | AFRICA | 1 | 06-25-2013 04:25 AM |
