Old 02-15-2018, 05:58 PM   #29
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Modern engines are designed to burn a bit of oil for the sake of longevity and mpg. Just check it every week or two and top up when it's near the low mark.
Also, always wipe your dipstick.
Alsoalso, this seems familiar...
http://www.ft86club.com/forums/showthread.php?t=119993
The Following User Says Thank You to Spuds For This Useful Post:
Beachin86 (02-15-2018)
Old 02-15-2018, 06:02 PM   #30
ermax
ermax's Avatar
Originally Posted by BirdTRD View Post
F108S for the win!
Actually I went back and looked at my order. I didn't get the SX I got the S.
There are these versions:
F108: No nipple
F108N: Long nipple (this is the one that I read goes past the cover)
F108S: Short nipple
F108SX: This one has a short nipple but is at a 90
I'm thinking I should have gotten the SX. Oh well, too late now.
So, does the F108S extent past the engine cover? I really hope not, that sounds like a recipe for disaster. From your picture it looks like it is safely recessed.
Old 02-15-2018, 06:07 PM   #31
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Oh yeah, can you confirm that you are pulling the dipstick out, wiping it clean with a paper towel, then reinserting it, removing it, and taking a visual reading at that point?
Also you mentioned color a few times, the color of the oil doesn't have anything to do with the life of or "capacity" left in the oil.
Originally Posted by humfrz
I'm old and lazy
Cole (02-15-2018)
Old 02-15-2018, 06:11 PM   #32
Spuds
The Dictater
Spuds's Avatar
F108: No nipple
F108S: Short nipple
That's the one I have. It does not as I recall. I'll confirm when I get into my garage tonight to check.
Old 02-15-2018, 07:43 PM   #33
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Nope
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
ermax (02-15-2018)
Old 02-15-2018, 08:21 PM   #34
@Tcoat page
Never got the notice but doesn't look like I caould do more than repeat what has been said anyway.
Originally Posted by Thorpedo View Post
Rub dipstick with scotchbrite.
Run engine for 5 min.
PARK ON LEVEL GROUND.
Shut engine off, pull dipstick.
Let sit for 3 minutes.
Insert dipstick, pull out dipstick
Read both sides, lowest side is right.
This ^ alway do this. A mildly abraded dipstick is a happy dipstick.
Originally Posted by mjanmohammad View Post
you shouldn't be seeing a significant amount of metal on a magnetic drain plug at all. 90% of the FA20 engine is non-ferrous metals so they aren't magnetic.
My recommendation for you here is to get the Fumoto valve, and send a sample to Blackstone for analysis when you do change the oil.
This as well ^ If you are getting loads of chunks of ferrous metals on a magnetic plug you already are too late to do much.
If you're really serious about ferrous metals in the oil,
get some neodymium magnets to put on the outside of the oil filter.
It all gets stuck in the filter and you can re-use them on the next filter.
Not sure what the benefit would be. If the metal is large enough to make it to the filter then it will get ... well.. filtered. If too small for the filter to grab it isn't causing any issue anyway.
Old 02-15-2018, 08:54 PM   #35
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
That was my thought. Looks like the dipstick when you initially pull it out. Still could be low though
Old 02-15-2018, 09:13 PM   #36
ermax
ermax's Avatar
Nope
Perfect. Thanks for the info!
Old 02-15-2018, 10:15 PM   #37
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
'cause... Magnets yo!
They would catch particles going past and keep them there,
though wouldn't have any effect at all on aluminum, brass, bronze or gasket snot.
So not much really.
I did say "REALLY SERIOUS". Someone who was convinced it works gave me some.
They're still in the box on a shelf.
No. Wouldn't restrict flow at all.
The Following 2 Users Say Thank You to bcj For This Useful Post:
Beachin86 (02-16-2018), Tcoat (02-15-2018)
Old 02-15-2018, 11:15 PM   #38
highway7
Drives: FRS 2013
I check after parking my car overnight.
Pull dipstick, wipe
Insert dipstick the same way you pulled it out (Otherwise the dipstick will not show correct mark)
Wait a second or 2
Pull out dipstick, making sure not to allow oil to move up dipstick
Read the side of dipstick with lower reading that the entire width is covered
There will be some slight oil along the edge of the dipstick due to dipstick going in and out
If there is oil in the 'low oil' hole then you at least have oil at the min mark
highway7 is offline   Reply With Quote
The Following 2 Users Say Thank You to highway7 For This Useful Post:
Beachin86 (02-16-2018), Clipdat (02-16-2018)
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 07:24 PM
dip stick dilemma notout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 04-15-2015 06:52 AM
I should stick to my bicycle SeanBlader Northern California 1 11-18-2014 01:09 AM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 02:10 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 01:52 PM
