View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-09-2012, 02:11 AM   #169
sierra
Drives: Skoda Yeti DSG diesel 4x4
I haven't seen it mentioned on any Australian forums.
I have seen it mentioned that US diesel is some of the lowest quality in the world, unless that's changed with the new diesels being sold there recently? Maybe the past low tech nature of the engines because fuel consumption, with the cheap fuel, hasn't encouraged change, means the fuel standard needs to be upgraded to suit modern engines?
sierra is offline   Reply With Quote
Old 07-09-2012, 06:46 AM   #170
roddy
roddy's Avatar
Drives: '13 Ultramarine
I have been using Sunoco/Petro Canada Ultra 94 gasoline, which contains "up to 10%" ethanol. On my next fill, I'll try Shell 91 which contains no ethanol, and see if it makes any difference. I have some good 2-stroke oil here, but I hesitate to try this in case it causes an issue with the catalytic converters.
The Following User Says Thank You to roddy For This Useful Post:
excited86 (07-09-2012)
Old 07-09-2012, 07:35 AM   #171
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by excited86 View Post
This fuel type difference does not make sense. How can 20% of the people reported no issue? Did they use octane 94? How can we get ourselves into the 20%?
Some people either don't notice (have the stereo crank way up) or the chirping noise just haven't started yet.
Hanzo is offline   Reply With Quote
Old 07-09-2012, 08:01 AM   #172
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
....Time to start experimenting with additives.
Pscylo is offline   Reply With Quote
Old 07-09-2012, 08:17 AM   #173
LeftFootBrake
LeftFootBrake's Avatar
Drives: White 86 GTS AT
Can understand you missing it but I have made mention of it: LeftFootBrake's White GTS AT
LeftFootBrake is offline   Reply With Quote
Old 07-09-2012, 09:24 AM   #174
eindio
Drives: white frs auto, 02 corvette mn6
I havent noticed the noise but I did fill up with 100 octane onthe second fillup and I never let it get below a half tank
eindio is offline   Reply With Quote
Old 07-09-2012, 09:26 AM   #175
excited86
Drives: none
what is the noise situation for you right now?
Is petro canada ulta 94 giving you problem?
excited86 is offline   Reply With Quote
Old 07-09-2012, 09:30 AM   #176
sierra
Thanks. So it looks like we also have crap fuel or only Japan has a special lubricating additive? Are you game to try a bit of 2T to see if it shuts it up?
If it's squealing at idle because it's dry can you imagine what it's doing at normal rpm?
You make the auto sound a good thing.
Old 07-09-2012, 09:36 AM   #177
excited86
Drives: none
can you post what lub you are talking about? a picture of it perhaps?
Old 07-09-2012, 10:24 AM   #178
sierra
Two stroke oil that's designed to dilute in gasoline and lubricate metal surfaces. The same stuff everyone uses in their chain saws.
Just get a good quality racing oil and use a much smaller amount.
What could be better???
Old 07-09-2012, 10:25 AM   #179
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
So has anybody whos experienving the chirping tried using higher octanes? did it go away?
imravenit is offline   Reply With Quote
Old 07-09-2012, 10:29 AM   #180
excited86
Drives: none
This is a logistic nightmare. So I have to put some of this everytime I fill the tank?
Old 07-09-2012, 11:13 AM   #181
PoRco
Ef Arr Ess
Drives: Ablaze MT (2016)
Should I take back my deposit and wait for a fix on this?
That chirping sounds awful to me...
PoRco is offline   Reply With Quote
Old 07-09-2012, 11:22 AM   #182
Marrk
Drives: Honda Fit
I really, really dislike this option.
Is everyone who is promoting the It's-the-lack-of-lube-in-USDM-gas theory content, then, with the idea that the BRZ-FRS appears to be the only direct injection engine in the US that has a problem with USDM gasoline? Does this make sense?
Marrk is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
