Old 01-31-2018, 08:38 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by ApexEight View Post
I'm confused. OP says he's in OFT Stage 2 tune which disables the CEL. He does not have a CEL. The problem is that despite this, the OBD shows a readiness fault.
So the only way to pass is to put on a stock header and flash back to a stock tune/tune that does mot disable the CEL.
Right?
On his post from 2:19 he says he has on oxygen sensor code which is why I quoted it. That's where I was getting lost.
The stg 2 OTS tune I started with did not have P0420 disabled. I had to do it manually. So again, I was just confused as usual.
Old 01-31-2018, 09:31 PM   #16
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Christopher86 View Post
yea i have the stage 2 tune with tomei uels catless, no cel, everythings fine, but the smog says other wise. i dont have my stock header anymore, so last thing i want to do is find one to switch it out, trying to avoid that. visual testing is fine i passed, but the smog doesnt pass me for readiness. i have 2 errors
Whats the other one? You will always have one for the O² sensor check being disables (else your likely throw the CEL). It is possible you just need to drive it more.
Old 01-31-2018, 09:37 PM   #17
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I'm confused af now.
So if you have a catless header, and you have an OFT OTS tune, you need to edit the tune to disable the P0420 code, and then your car will show emissions readiness?
I just want to know how to have all emissions readiness when running a catless header and OFT OTS tune lol.
ApexEight is offline   Reply With Quote
Old 01-31-2018, 11:49 PM   #18
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
To piggyback on what @ApexEight said.
If you just need to pass smog with the least amount of headaches, put your OEM exhaust system back on and flash back to the factory tune.
After that whole fiasco is over with at the smog station, put your aftermarket parts back on and go back to OFT Stg 2.
EZPZ
TheMedakaBox is offline   Reply With Quote
Old 02-01-2018, 09:20 AM   #19
Jasonb
Drives: 17 Series Yellow BRZ
Sounds like a hassle and having to buy gaskets all the time
Jasonb is offline   Reply With Quote
The Following User Says Thank You to Jasonb For This Useful Post:
Chimera (02-01-2018)
Old 02-02-2018, 06:46 AM   #20
steve99
Drives: FT86
I can pass the visual inspections, its just that im having the oxygen sensor code with another error. Is it safe to go back to Stock tune or should I go to stage 1 tune with my catless uel header? I might try that to see if i can pass. but i dont want to tune my car if its going to hurt it, please let me know, thank you
Going back to stage 1 or stock will be fine you might throw p0420 code though
Old 02-02-2018, 07:36 AM   #21
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Why not get one of those CEL eliminator spacers and flash back to a stock tune. You'll be fine for emissions testing and its only one thing to change vs everyone saying change your whole exhaust.
If you're having an issue with the readiness / code, flashing to stock will fix that issue, but you will probably have the actual CEL at that point.
Old 02-09-2018, 09:18 AM   #22
Christopher86
Drives: White Auto 86
UPDATE:
this might help some of you.
i have UEL catless headers, + custom exhaust with no muffler only a resonator,
Stage 2 tune does not pass emission checks at all.
Flashed it back to OEM, drove around ~75 miles for drive cycle
I passed emissions.
Tuned back to stage 2,
No need to take headers off, might not be the same for everyone, but it worked for me!
Thank you to everyone that helped
Christopher86 is offline   Reply With Quote
Old 02-09-2018, 10:15 AM   #23
Randoman5
UPDATE:
I passed emissions.
If you flashed back to stock and you're missing an 02 sensor didn't you have a CEL?
Randoman5 is offline   Reply With Quote
Old 02-09-2018, 11:45 AM   #24
Chimera
Drives: FRS
I think he's got all the sensors, just no cat
Old 02-09-2018, 12:36 PM   #25
Christopher86
Had no CEL, only tranmission code, but thats normal on autos.
just erased the code , went on with the emission testing and passed
Old 02-09-2018, 01:15 PM   #26
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If I enable P0420 for the O2 efficiency CEL I don't get it for a couple days sometimes.
Old 02-09-2018, 03:47 PM   #27
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Curious if the Smog requirements in Vegas (i think thats where you said you are?) are different than in Cali (like your profile says you are).
Largely because noone i know has ever been able to pass a smog test in California with any sort of cat delete. Even flashing back to stock with a spacer to trick the ECU didnt pass. It definetly doesnt pass visual but some shops honestly dont check.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 02-10-2018, 05:32 PM   #28
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Wdym "normal" on autos, I've had my 86 for a long time and never got a transmission code. I've also passed OBD2 smog checks with the stage 2 tune.
Best EL catless header? shu5892001 Engine, Exhaust, Transmission 38 01-22-2018 10:36 PM
catted headers + OFT = automatic smog fail? DarkSideFRS Southern California 7 12-12-2017 03:24 PM
catless header vs catless frontpipe steveholt Engine, Exhaust, Transmission 30 10-10-2017 07:13 PM
Best UEL catless header bozack Engine, Exhaust, Transmission 13 04-24-2015 02:00 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
