Old 02-07-2018, 12:22 AM   #309
Originally Posted by Jordanwolf View Post
Aren't variable compression ratio engines like brand new?
Good observation......
Yep, the concept is only about 20 years old.
Old 02-07-2018, 06:22 AM   #310
ermax
ermax's Avatar
Let’s just say pressures did drop as revs built. That doesn’t mean the rings suddenly loose their spring effect and stop their contact with the sleeves or even reduce their outward force. I mean you could pull the plugs out but that wouldn’t prevent the rings from doing their job. If pressures dropped it would for sure drop the load on the bottom end but there isn’t any metal to metal contact in the bottom end anyways. The rods essentially ride on oil unlike the rings which are essentially scraping oil off the cylinders (why we don’t have purple smoke out the back).
Still can’t wrap my head around the pressures dropping on an engine that builds power all the way to redline. Not doubting anyone, just can’t wrap my head around it and would love to hear more.
Old 02-07-2018, 08:54 AM   #311
Tokay444
Anti stance.
Tokay444's Avatar
Max cylinder pressure is at max torque. Not max horsepower.
Cylinder pressure is dynamic and in direct relation to valve timing and ignition timing.
Old 02-07-2018, 11:06 AM   #312
Jordanwolf
Rice King
Jordanwolf's Avatar
I haven't really heard of them being applied to cars besides the infiniti so far.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 02-07-2018, 12:50 PM   #313
Yep, for sure ....... as with any four cycle, internal combustion engine.
(intake-compression-power-exhaust)
Old 02-07-2018, 12:56 PM   #314
Tokay444
Anti stance.
Tokay444's Avatar
Yep, for sure ....... as with any variable valve timing, variable ignition timing, internal combustion engine.
Old 02-07-2018, 12:59 PM   #315
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Did you not get the memo that the most fun in this car happens between 4-7k RPM?
Why would you be only getting to 4.5k rpm when you're "really pushing it"? News flash, you aren't really pushing it.
This is truth. @op so you mean to tell me you've never downshifted into 3rd on the highway and floored it from 5K to 7K...... or pulled 2nd gear all the way up... Wait has your engine ever even seen redline??? These were designed to be pushed past the limit. Your engine is fine lol.
TorontoNat is offline   Reply With Quote
Old 02-07-2018, 01:02 PM   #316
Oh, my bad ...... I meant 1920 ...... not 20 years old ......
From Wiki:
"The first VCR engine built and tested was by Harry Ricardo in the 1920s".
Old 02-07-2018, 01:04 PM   #317
Yes, including that kind too ......
Old 02-07-2018, 01:08 PM   #318
ermax
ermax's Avatar
Right but it still climes (torque) almost all the way to redline.
I still feel like the number of times the rings runs up and down the cylinder would have an impact on wear. I mean the ring closest to the skirt is called the scraper ring for crying out loud. It's job is to scrape the oil off the walls so it doesn't end up in the combustion chamber. It's spring loaded to press outward onto the walls. This can't possibly not cause more wear when doubling the number of times it passes in its lifetime. You also can't tell me rings/skits have an infinite lifespan. If that was the case you wouldn't see all these boy racers in Honda's blowing smoke all over the place. I can also tell you form first hand experience from my Integra. At 200k I was burning one qt per day (not an exaggeration). It wasn't leaking, it came out the back. I left a smoke screen and crap all over the cars behind me. Why did it do this, because I drove the piss out of it. I was one of the boy racers never cruising under 4K.
Old 02-07-2018, 01:11 PM   #319
StraightOuttaCanadaEh
Wes
If I'm on the highway, I'm usually shifting from 6th to 5th. Usually by the time the on ramp ends, I'm either in 5th or 6th depending on the impending need to overtake. If I see no traffic coming up, I chill and let her get to 130-140 at her own pace. Sometimes I feel like having fun and stretch it out in 3rd to 7K, but that's for a few seconds and I wasn't worried about that. 10-15 minutes at 4K was what I was concerned about.
Instagram: @gt86ws
Old 02-07-2018, 01:14 PM   #320
Wes
I tend to agree with your posts. Your conclusion just makes more sense logically speaking. I don't know, we might be wrong but it just seems to be common sense.
Instagram: @gt86ws
Old 02-07-2018, 01:16 PM   #321
Jordanwolf
Rice King
Jordanwolf's Avatar
From Wiki:
It's not exactly commercialised though?
Glorious Honda.
Old 02-07-2018, 01:19 PM   #322
ermax
ermax's Avatar
Again... the thread is talking about "cruising". Not passing... not racing... not accelerating just for the freaking hell of it (me). Hahaha.
Opti - coat 2.0 (pro) vs waxing regularly radroach Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 01-19-2018 09:39 PM
Who else regularly checks BaT? NWFRS Other Vehicles & General Automotive Discussions 8 08-16-2014 12:02 AM
High rpm cruising in 6th abutterman Issues | Warranty | Recalls / TSB 12 03-22-2013 07:38 AM
Fr-S w/ Evo X cruising in SoCal NGabriel89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-12-2012 06:19 PM
JRP FR-S/BRZ build up (regularly updated) Stav CANADA 5 07-14-2012 04:21 PM
