#267 | |
[ame="https://www.youtube.com/watch?v=T4Qw-bmt7Ss"]Low Gear Bike Race - YouTube[/ame] Don't lie Tcoat, you know this is funny. Hahaha |
#268 | |
Persona Non Grata
Drives: '15 BRZ (WRB)
If you change the question and ask which engine would have more wear, one that covered 10,000 miles at 3500 rpm v one that covered 5,000 miles at 3500 rpm the answer is, I think obvious. Better for Humfrz to ask whether two cars cover the same distance with one at twice the velocity of the other (but still within the "normal" operating envelope of the engine) would experience differential engine wear is more like it. Another question I have is what part of the engine are we talking about. Is it the bearings (rod and main), seals, cylinders, pistons, rings, water pump oil pump or what? As most who have spent much time in engines know, cylinders have a habit of wearing an a "hourglass" shape. The tops as bottoms exhibit more wear than the centers. Why? Because the lubrication film between the rings/pistons and the cylinders breaks down as the pistons slow to a stop at the tops and bottoms of their strokes. The centers of the bores, where piston speeds are at their highest, have the most effective lubrication because the oil film is more effective at the higher piston speeds. Thus, it would seem that increased speed can result in reduced wear. My conclusion is this is much ado about absolutely nothing. If you drive your car in a lower gear, your engine will turn more revolutions. Those extra revolutions will cause incrementally more wear. If you drive the same distance, in the same gear, but simply at a higher speed, (say cruising at 90 - 4000 instead of 80- 3500) the wear difference will be less than trivial.
Slow is smooth, and smooth is fast
| The Following 3 Users Say Thank You to Capt Spaulding For This Useful Post: |
#269 | |
Super Saiyan
Drives: 9000 HP FRS
| The Following User Says Thank You to ImAdopted For This Useful Post: | Audio (02-06-2018) |
#270 | |
Two engines on an engine dyno with proper cooling to simulate travel at 60mph. Both will operate 24/7 for one month. One engine will be turning 4000rpm the entire time and the other will be turning 2000rpm the entire time. No transmission, no distance is covered. I think it's obvious which one would wear the most. And then a real world comparison. When cruising on the highway at a consistent speed, the same speed for an hour. Which one will have more wear, one that is driven the whole time in say 4th (yes one guy said he actually cruises on the highway in 4th) or one driven in 6th? Again, completely obvious. How much additional wear may be negligible I agree. But that doesn't change the facts. As for which part of the engine would wear. Well any part that is moving. But primarily the ring to sleeve contact. If two parts are incontact with one another there will be wear. If the number of passes is higher in one scenarios vs another it will definitely wear more. Why are we even debating this (not directed at you, you obviously understand the topic)? It's so incredibly obvious. |
#271 |
Super Saiyan
Drives: 9000 HP FRS
i do about 99% highway driving throughout the week and since im in no rush ever i cruise (my own opinion about cruise) around 102 km/h which puts me at around the 2100 rpm mark. reading this thread makes me worried now, am i gonna die? is my engine gonna blow?
#272 | |
Yep. Too low. Hahaha. You need to put it in 4th. Get those revs up around 4500 if possible.
#273 | |
Super Saiyan
Drives: 9000 HP FRS
#274 | |
Not a troll
I understand that provided it's within operating spec, it will be fine, but theoretically, wouldn't it show twice the wear of the other engine? |
| The Following User Says Thank You to Cole For This Useful Post: | Jordanwolf (02-06-2018) |
#275 |
Wes
Study results:
Inconclusive. lol
Instagram: @gt86ws
#276 | |
Rice King
base wear when car is running = 1 wear at 2000 rpm = 1.2 wear at 4000 rpm = 2.4 As opposed to, wear at 4000 rpm = 1.4 Disclaimer: Numbers are used as an example and no valid math was used here.
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#277 | |
Not a troll
#278 |
The diference between your engine lasting 1,000,000 miles and 999,999.00000000000000000000000000009
| The Following User Says Thank You to Tcoat For This Useful Post: | Vic4uf (02-06-2018) |
#279 |
Drives: 2013 frs red
5000rpm and 15k oil changes. Rev er up!
#280 | |
Cruising regularly at 4000 rpm
Yeah for sure not double due to improved oil flow. But yes more, extra, additional. Hahaha |
| The Following User Says Thank You to ermax For This Useful Post: | Cole (02-06-2018) |
| Opti - coat 2.0 (pro) vs waxing regularly | radroach | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 34 | 01-19-2018 09:39 PM |
| Who else regularly checks BaT? | NWFRS | Other Vehicles & General Automotive Discussions | 8 | 08-16-2014 12:02 AM |
| High rpm cruising in 6th | abutterman | Issues | Warranty | Recalls / TSB | 12 | 03-22-2013 07:38 AM |
| Fr-S w/ Evo X cruising in SoCal | NGabriel89 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 09-12-2012 06:19 PM |
| JRP FR-S/BRZ build up (regularly updated) | Stav | CANADA | 5 | 07-14-2012 04:21 PM |
