Old 02-06-2018, 03:10 AM   #1
Hags86
Drives: Toyota GTS 86
Does anyone make a decent - functional - splitter
Hi All
I'm in the market for a functional splitter. There are lots of nice cosmetic ones that don't interest me.
My requirements are:
- extend from in-front of the bumper lip all the way to the front wheels and across the underbody as one flat piece (like the APR one).
- be parallel to the ground (the APR one is just a flat board so follows the contour of the bumper which faces up about 30-40mm)
- be solid mounted at the front and back (happy to build brackets etc if required).
- ideally carbon but will to consider anything. Function over aesthetics...
Looking forward hearing your suggestions.
Hags86 is offline   Reply With Quote
Old 02-06-2018, 07:28 AM   #2
plucas
plucas's Avatar
Drives: Subaru
Originally Posted by Hags86 View Post
Hi All
We offer 2 different ones at 2 different price points. Our first is our carbon composite splitter which is a carbon thermoplastic which can handle much more impacts than normal carbon. It can also be scraped across the ground with little damage.
https://www.verus-engineering.com/pr...front-splitter
Our other option is a plastic front splitter of similar design as the above. The difference is the material, mounting, and adjustability. Depending on the year, we have 2 options for fitment. We also recommend race upgrade for added strength.
https://www.verus-engineering.com/pr...litter-upgrade
Feel free to email us with any questions
sales@verus-enginnering.com
plucas is offline   Reply With Quote
Old 02-06-2018, 08:56 AM   #3
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Ater going off track with a body mount splitter and pulling the bumper cover off I decided to make my own out of 3/8ths plywood. and I made my own frame mount, so the splitter does mot attach to the body. Now if I were to go off track and dig a bunch of dirt the plywood splitter would just break apart with out hurting my body.
Lunatic is offline   Reply With Quote
Old 02-06-2018, 10:06 AM   #4
Jonsey
Jonsey's Avatar
Probably the only off-the-shelf splitter I would run. Carbon, chassis mounted and plenty strong. https://www.86speed.com/products/mph...r-frs-brz.html
Like Lunatic, I have run both a plywood and corrugated plastic splitter as I consider them a disposable wear item and so don't want to pay for carbon.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 02-06-2018, 01:27 PM   #5
Hags86
I like your ideas @Lunatic and @jonesy. I'm doing something similar with the crash bar, oil coolers and shrouds.
But how do you get the splitter sitting parallel to ground? From what i can see the Verus, MPH, APR and home made designs all follow the contour of the underside of the bumper therefore taper up quite a bit. How would you seal that 30mm gap at the front if it was to be mounted parallel to the ground?
(@plucas I really like the Verus rear diffuser...)
Old 02-06-2018, 01:59 PM   #6
Lunatic
Lunatic's Avatar
I also have an aftermarket lip which helped in keeping the splitter flat.
Old 02-06-2018, 02:27 PM   #7
Hags86
Which one?
Old 02-06-2018, 03:17 PM   #8
Jonsey
Jonsey's Avatar
Mine has a single fixed chassis mount at the back and then eight adjustable rods to allow me to make it parallel to the ground. I can add spacers if necessary to the rear mount to lower the splitter, but mine sits at a comfortable 3" everywhere based on my ride height. I then used plastic garden edging to build a dam between the bumper and splitter.
I believe the MPH one is similarly adjustable, but haven't verified.
Old 02-06-2018, 03:49 PM   #9
Hags86
Could you please attach a photo of the air dam. This is the sort of thing I'll need.
Old 02-06-2018, 03:50 PM   #10
DAEMANO
Time Traveller
Hi All
Verus Engineering, APR, and Wasp Composites are what comes to mind if you want function over form. There's a lot of info on the board. Search tool is your friend. Still if you need something custom, you may just better off making it yourself.
Old 02-06-2018, 05:15 PM   #11
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I had a custom unit made out of MDO. That's Medium Density Overlay, a plywood product with a resin-impregnated surface, typically used for outdoor signs.
The shop chose MDO because it was easy to work with, especially when it came to routing the bullnose into the leading edge of the splitter.
MDO is not light, but it's dimensionally very stable. When properly supported it will hold many hundreds of pounds of downforce without flexing. Mine was quite resilient - I used it for two years before selling the car on which it was mounted.
MDO also has a smooth surface that looks good when painted.
dradernh is offline   Reply With Quote
Old 02-06-2018, 08:19 PM   #12
Lunatic
Lunatic's Avatar
Which one?
https://www.ebay.ca/itm/For-13-16-Sc....c100005.m1851
Old 02-06-2018, 08:31 PM   #13
Hags86
Unless a viable option turns up it looks like I'll try and make something custom. There are a number of off-the-shelf items and I'm happy to pay for them, but none sit parallel to the ground. So you either have it tapering upwards to the front (creating lift I guess) or end up needing to build a custom air dam to block the 30mm gap between the splitter and the bottom of the front lip. If I'm going to have to build something, then I may as well just build something.
My plan is to use 10mm marine plywood. I'll then build a wedge shaped dam attached to the splitter that blocks the gap and route a nice profile on the dam. Then carbon fibre skin the visible parts of the splitter. It won't be nearly as pretty at the commercial products, but it will sit flat and not have a gap.
Functional Rice Car thien Member's Car Journals 44 01-17-2018 11:50 AM
Does anyone make a stronger RB V2 front splitter? ap3x Cosmetic Modification (Interior/Exterior/Lighting) 0 09-03-2017 12:08 AM
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
My ''decent'' daily 86 adrianfrs Member's Car Journals 8 06-08-2016 03:22 PM
