Old 02-04-2018, 11:57 AM   #113
Jamestl
Drives: None
[QUOTE=ApexEight;3038917]That's exactly what I did and the ECU swap alone got rid of my CEL. It's been about 3 weeks now.[/
Keep us posted! Mine went away when I swapped the sensors but only for like two months. Fingers crossed for you!
Jamestl is offline   Reply With Quote
Old 02-04-2018, 12:20 PM   #114
Teseo
Drives: frs
Anything to preventing that issue?
Old 02-04-2018, 02:56 PM   #115
Originally Posted by Jamestl View Post
The thing that pisses me off is that you don’t actually know whether sprocket has failed. If I just reset the ECU everything worked as before - I noticed zero change. I’m almost tempted to get a new ECU before I change the sprocket given the cost differential. Sigh...
Yeah. It really bugs me that it's such a secret.
Apologies for not first circling back around to your case, Apex. I did take it into account but forgot to explain here.
Do you think it's possible that you cleared the interference in the valve the first time you had it apart? That was my thought. It would also explain why, in my friend's case, the code returned even after we found the interference.
Old 02-04-2018, 03:07 PM   #116
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
The OCV? I'm not sure.
Here's the exact sequence of events:
1) Started car on a slight incline late at night leaving a friend's house. It was cold. About 1 mile down the road I get the slip angle light illumination and CEL. Ran the codes and I got I think P0420 for cat efficiency (had this code once before so I wasn't too worried because it went away the first time) and P0016 which I didn't really understand at the time.
2) Pulled over and cleared the codes. Car drove without re-illuminating the whole way home. I later learned that P0016 takes two drive cycles to re-appear after being cleared.
3) Swapped cam sensors. Nothing.
4) Swapped OCVs. Nothing.
5) Massaged OCV and cam sprocket "plungers". Nothing.
6) Learned that I was about half a quart of oil. Re-filled. Nothing.
7) Changed the oil. Nothing.
8) Swapped ECUs. CEL gone.
During this time, I had no drivability changes, other than being in limp mode. The car idled and drove the same otherwise.
I wouldn't be surprised if my cam sprocket is missing the little plate with the spring beneath it, or shows some visible damage, or maybe even has the lag in VVT timing or whatever (I don't really understand that stuff). All I know is the car feels as strong as ever and I'm so glad the CEL is gone lol.
I have a buddy who has a 2013 FR-S and he had a P0016 a while back. He got the ECU replaced under warranty and it cleared the code. It hasn't come back in the ~40K miles he's been driving since. I'm on 3 weeks. I just hope that it's gone for good.
ApexEight is offline   Reply With Quote
The Following 2 Users Say Thank You to ApexEight For This Useful Post:
ShadowReaper (12-11-2024), Ultramaroon (02-04-2018)
Old 02-04-2018, 03:21 PM   #117
TheStig85
Drives: 2013 Subaru BRZ
I'm in the same boat and did almost exactly what you did but my CEL came back after 9 months. I'm debating it but I'm probably have to remove the sprocket and inspect the plate.
Sent from my Pixel 2 XL using Tapatalk
TheStig85 is offline   Reply With Quote
Old 02-04-2018, 03:26 PM   #118
No, but you covered it in step 5. ...the sprocket plunger.
I have to start over because nothing makes sense.
If anyone reading this thread manages to save a failed sprocket assembly, I'd gladly pay for shipping and the hassle of boxing it.
Old 02-04-2018, 03:48 PM   #119
ApexEight
Damn, that sucks. Does your car ever run low on oil? I wouldn't be surprised if this has something to do with the ECU seeing a low oil pressure condition for even a split second.
Old 02-04-2018, 04:09 PM   #120
TheStig85
Maybe... Ever since I had my oil cooler installed, I was never 100% sure on how much oil to add. I'll double check it later. Thanks!
Old 02-04-2018, 04:42 PM   #121
ECU doesn't monitor oil pressure.
Old 02-04-2018, 11:13 PM   #122
Jamestl
Drives: None
Seriously... where the actual mechanical failure for this stupid code.
Old 02-05-2018, 12:03 AM   #123
The actual mechanical failure is anything inside the cam sprocket that causes it (the phasor) to quit responding appropriately to commands from the solenoid, which is inaccurately called the "oil control valve."
Everything else is electrical.
Old 02-05-2018, 12:33 AM   #124
Jamestl
Drives: None
No I get that. I’m just saying that we all go through this stupid process and don’t know whether there was actually a mechanical failure. I thought hat was your point - trying to pinpoint where the mechanical part failed.
Old 02-05-2018, 12:53 AM   #125
Oh. Oops.
Yeah, it is. I'm dying to figure out this damn thing.
Old 02-08-2018, 09:22 PM   #126
rusty959
Drives: DGM BRZ limited
If you don't mind me taking it apart myself first I'll send you mine. Finally home now so I'll be putting things back together in the next week or so.
rusty959 is offline   Reply With Quote
P0016 fixable without new ECU? Mr.Jay Issues | Warranty | Recalls / TSB 8 02-06-2022 05:15 AM
P0016/P0017 cause AVOturboworld Issues | Warranty | Recalls / TSB 18 04-16-2021 11:09 PM
P0016 Code Shady195 Engine, Exhaust, Transmission 30 02-21-2019 02:31 PM
p0016 need help asap lol Issues | Warranty | Recalls / TSB 25 10-30-2018 03:49 PM
OFT P0016 and TSB question mmmcambelsoup Software Tuning 10 05-24-2017 09:24 AM
