Old 01-25-2018, 09:01 PM   #477
Teseo
Drives: frs
Originally Posted by PuslarBrrrz View Post
He's already on to the V4 tunes for the MY17+ according to the OFT FB page.
I did not see anything, can you provide the link?
Teseo is online now   Reply With Quote
The Following User Says Thank You to Teseo For This Useful Post:
Somerandom18 (01-25-2018)
Old 01-25-2018, 10:19 PM   #478
D_Thissen
D_Thissen's Avatar
Yup, I saw that too.
Old 01-25-2018, 11:02 PM   #479
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
actually...
Originally Posted by churchx View Post
But as there appeared OFT flex fuel tunes by reading from ethanol sensor, i guess it's potentially doable, if someone writes similar code that switches maps depending on some other readings ..
you could use the same tune. All you would have to do is create a little switch that will output 4.5v for 93 and 0v for 91... and hook it to the same connection.
Hell you could even do something for in between, 92 or slightly better 91(non-cali) Have a potentiometer that controls the voltage output.
Shit you could take logs watching for knock and just dial up the potentiometer until you start to see knock and back it off a bit. Hell, it's live tuning lol...
It would still be limited because it is a base interpolation from the two maps, it's not like you'd be dialing it in for specific rpms and what not. But it would be a form of live tuning. Hell Shiv could build in an output from the OFT in future versions that would allow for it using the stage 1 and stage 2 maps or the 91 and 93 maps. Just dial up the voltage.
Hey Steve or Wayno or Ztan, how difficult would it be to tie in automatic knock based interpolation?
Yeah it should be fairly simple to use knock inputs as an interpolation source instead of the flex sensor. Not sure how dangerous it would be though, I guess it would depend on how quickly it adapts, but I would think that you could use some type of delayed trigger that finds a safe zone and keeps it there for a while.
Jaden
Jaden is offline   Reply With Quote
Old 01-26-2018, 02:03 AM   #480
JermMX5
Drives: 2017 Toyota 86
Just checked the Open Flash Page and the 86 Owners page and couldn't find anything, mind posting the link to the post?
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
Old 01-26-2018, 02:03 AM   #481
PuslarBrrrz
https://www.facebook.com/photo.php?f...3458821&type=3
PuslarBrrrz is offline   Reply With Quote
The Following 2 Users Say Thank You to PuslarBrrrz For This Useful Post:
Breadman (01-26-2018), Teseo (01-26-2018)
Old 01-26-2018, 07:50 AM   #482
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
oh shit when/where can i get this?
Old 01-29-2018, 02:20 PM   #483
timmydatooth
Drives: Scion Frs
have the OTS v3.0 tune files come out yet for the 2013 scion FRS or are we still waiting on those? it seems like v3.0 only came out for the newer 2017 86's
timmydatooth is offline   Reply With Quote
Old 02-01-2018, 07:51 AM   #484
mrmamba
mrmamba's Avatar
Drives: GT 86 2017
Hello all,
I own a 2017 of Europe (so 2017 version with old ecu logic and old motor) and I see an update on the tablet when I plug it to the computer, the version change to 01.47 to 01.49, do this update is the new version that have proper logging on the 2017 cars?
Regards!
mrmamba is offline   Reply With Quote
Old 02-04-2018, 12:33 PM   #485
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Can anyone with a 2017 car and OFT confirm that logging works now?
Waiting to buy an OFT again until I can actually use the thing to log my tune.
TofuJoe is offline   Reply With Quote
Old 02-04-2018, 01:28 PM   #486
Impureclient
Drives: 2015 FR-S
I emailed Shiv and he sent me the v3.0 for mine in 5 days but in the meantime while I was waiting for that, the member Tor in here is doing a custom tune so in the end I didn't need it since the custom one will be better tailored for my car.
Old 02-04-2018, 03:28 PM   #487
PuslarBrrrz
AFAIK the v3.0 and V4 are exclusive to MY17+ as the 13-16 tunes are already well worked.
Old 02-04-2018, 10:08 PM   #488
Impureclient
Drives: 2015 FR-S
I have a MY15.
So something was changed.
Old 02-05-2018, 09:36 AM   #489
My Key
My Key's Avatar
Drives: 2017 Toyota 86 - Raven
Originally Posted by Impureclient View Post
I have a MY15.
Did you check the files shiv sent to see if they are for the older models?
Sent from my SM-G955U using Tapatalk
My Key is offline   Reply With Quote
Old 02-05-2018, 01:10 PM   #490
Spyro
Drives: 2017 BRZ 6MT
I should be receiving mine some time this week, so I will let you know once I set it up.
Spyro is offline   Reply With Quote
The Following User Says Thank You to Spyro For This Useful Post:
TofuJoe (02-05-2018)
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
