#3053 |
Drives: Some kind of Subaru
Weird. I'm pretty sure one of my friends is also using the OFT UEL Stage 2 tune as well. I've driven his car a few times and the RPMs would stay at the rev limiter and not cut power.
#3054 |
Drives: '13 FRS - STX
Also on OFT stage 2 (EL) I think early versions of the canned tunes didn't have the raised redline and soft rev limiter but later ones do (at least as of a few months ago when I downloaded mine). Works out to about 61 mph in 2nd on a pre-facelift MT.
#3055 |
Drives: 2013 Raven FR-S
Hmm, maybe it was when I was running an older tune. I'll have to do a 2nd gear pull soon and see if it's still happening. Thanks!
#3056 | |
Drives: 2017 BRZ
I'll start the season on nearly dead 245 stones and barely used bfg's. I like the willingness to put up with my ham fisted driving in the bfg but the stone is faster out here for a precise driver. I'll try 255 again when its time for new tires, though driving a 17 now that may be the sweet spot.
#3057 |
Drives: '22 BRZ
I had the OFT tune on my car and it would sit smoothly on the limiter for half a second or so then closed the throttle part way and kept slowing down... I was at the limiter midway through a slalom and by the end of it I was doing mid 50s even with my foot on the floor the entire time.
So yeah, do some testing to make sure the limiter is set up correctly.
#3058 | |
Drives: 2014 Subaru BRZ
#3059 |
APEXHNTR
Drives: 10 Series FR-S #1867
The Rivals and 71R's seem to be pretty equal, I think it comes more down to how each tire matches your driving style than anything.
BUT if you're into ProSolos, BFG is once again running their contingencies so that may be a deciding factor...
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
| The Following User Says Thank You to Silver Ignition For This Useful Post: | smg1138 (02-03-2018) |
#3060 |
Drives: '22 BRZ
Shouldn't be an issue in a slalom with ~1/4 tank of gas, it was consistent too
#3061 | |
Pretty much this. Both tires are good tires. Pretty much comes to your preference on how the tire reacts to an input and how you setup the car around that. BFG paying out pros and actual tires instead of money was good start for me to try them out last year. While Lincoln it was kind of a dumpster fire, I think they performed really well and I didn’t have the car setup correct for that surface. YMMV Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
#3062 |
So basically the 245's work better on 2013-2016 models due to the gearing, right?
#3063 |
btr.life
Drives: 2022 GR86
I don't know if they are better. I know of plenty of people that ran the 255 on older cars (one being a friend of mine who was 3rd at Nats a couple years ago). The gearing might be part of it, but less so on pre-17 cars.
#3064 |
STX 188
They all trash.
| The Following User Says Thank You to tigermack For This Useful Post: | 2superblus (02-06-2018) |
#3065 |
Suspension Nerd
Drives: 2019 Mazda MX-5
OS Giken / Bridgestone / Lot-USA BRIDE
#3066 | |
Drives: 2013 Satin White Pearl BRZ
Sent from my Pixel using Tapatalk |
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
