Old 01-31-2018, 12:29 AM   #71
Zentec
Drives: 2017 Toyota 86
Originally Posted by 007BRZ View Post
000BRZ
In my Previous posts I replaced The 2017 BRZ Headset with a Kenwood DNX893S (there is a newer one coming out).
If you use this unit Update the operating system to the latest 2017 version with at least a 8GB SDX SD card. and also the maps...IT'S FREE!!!
With idatalink & Maestro 99% works.
Uses Sirius Antenna(DON'T BUY ONE)
Steering Wheel control work (now) old BRZ\FRS there is a control kit
Appleplay and Andriod Play work
OEM rear camera works, Kenwood Front Camera works(use to front park so I don't hit my lip)
HAVE TO USE KENWOOD MICROPHONE (OEM WILL NOT WORK)
Garmin MAPS is heaven sent. With the 2017 Operating System update the graphics are greatly improved too.
Spacers for the sides come from Crutchfield
Getting most car data, gauges system info, tire Pressure and TEMPERATURE
Has every option for controlling music quality, crossover, special settings
(I added a 75 WATT Kenwood AMP and all new Alpine speakers
I used a 2015 dash trim to replace the trapezoidal trim (the right side panel is shorter than the 2017 (so you HAVE to replace both, AND if your stupid enough to install a 2017 headset in a 2013-2016 YOU NEED BOTH THE 2017 HS TRIM AND SIDE PANELS)
The leather peels off the 2017 right panel and you can wrap it on the older panel by removing 1/32" off the straight side (see my photo) You cad also buy any color and stitching leather for $95 on Amazon to wrap both.
You can play DVD's, CD's run music off the SD card, also use a USB memory clip to Program update and music
The updating is as simple as apple pie if you follow the instructions
Hope you enjoy my experience
(I highly recommend you use a Kenwood/idatalink/Maestro experienced installer unless you are an MIT Post Doctorate Nuclear Physicist.
Question so if I have the Toyota 86 how can I get the gauges on the hu like that ?
Zentec is offline   Reply With Quote
Old 01-31-2018, 01:50 AM   #72
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
buy a kenwood and get idatalink installed.
otherwise get a bluetooth odb adapter and use torque app
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 01-31-2018, 05:50 AM   #73
I like physical too but there is no way my vinyl records would not fit in the car.
Old 01-31-2018, 10:34 AM   #74
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
LOL but how is this physically possible!?!?!?! That record player must have been mounted on it's own suspension and most likely still skipped on dumpy roads haha.
TorontoNat is offline   Reply With Quote
Old 01-31-2018, 10:39 AM   #75
I have seen one operate in real life and they worked surprisingly well actually. Helps that the old style records have groves about a half inch deep.
TorontoNat (01-31-2018)
Old 01-31-2018, 04:07 PM   #76
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What?
Originally Posted by humfrz
I'm old and lazy
Tcoat (01-31-2018)
Old 01-31-2018, 04:09 PM   #77
What?
Well they SEEM that deep.
Old 02-03-2018, 01:55 AM   #78
Zentec
If I get the idata link and Kenwood hu it will display the data? Can I add custom items like oil temp if I have an oil cooler?
It’s a chunk of cash plus install and I still would like to keep all of my original controls ect.
Joying Android 4.4.4 Kitkat Toyota Head Unit Griffon Electronics | Audio | NAV | Infotainment 542 09-12-2017 10:49 PM
2017 Toyota 86 head unit help..... PetrolioBenzina Electronics | Audio | NAV | Infotainment 0 10-16-2016 09:01 PM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
Toyota 86 GTS stock head unit won't turn on. ZN6_88 AUSTRALIA 3 04-23-2014 08:50 AM
