Old 01-29-2018, 01:17 PM   #1
redwine
Need advice... changing oil filter
Hello,
I am thinking to do a mid-interval EO & Oil Filter change myself.
Have some question regarding the oil filter....
The Svc Manual state "Use an oil filter wrench with a size of 80 mm (3.15 in"),
Is the tooling in the link the correct size for my Brz ?
I suppose it will work on any Oil Filter that is compatible with Brz right, or at least most oil filter brand ?
https://www.lazada.sg/sunshine-903-a...7376c303yVEgKk
Also,
if you dont have a torque meter,
the Manual state "3/4 turn".
That means upon "finger tight" (filter lip touching the base),
you turn another 270deg right ?
Thanks
redwine is offline   Reply With Quote
Old 01-29-2018, 01:46 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
It all depends on which filter was used. The one in the link looks like it will fit the OEM filter and possibly 80% of all the filters out there.
I didn't need any tools when removing mine, it came off with a little elbow grease. I have only screwed them on until hand tight. Just check for leaks after you crank it up.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-29-2018, 02:31 PM   #3
Grady
Grady's Avatar
3/4 turn after touching is correct of you do not have torque wrench. This filter is easy to access so a wrench for removal should not be needed if installed and lubricated corect. Instead of oil use Dow Corning DC4 or equivalent to lubricate gasket when installing. Will make removal a lot easier.
Old 01-29-2018, 03:24 PM   #4
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
You don't need a specific wrench. The filter is on top and fairly easy to access.
I use a strap wrench since I already had one. Hand tighten only.
Check each time that the gasket hasn't stuck onto the block and clean the surface.
The FuMoto quick drain oil pan plug replacement comes in handy to get the old oil out.
This should be torqued to spec, but that's only once and you won't strip the plug hole later.
Old 01-29-2018, 03:39 PM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
The location of the filter makes it nice and easy, as mentioned. When removing, a strap wrench or one of these makes it a snap if hand-twist is not sufficient.
Tighten according to specifications in manual, check for leaks after installation.
R1 3 5
. 2 4 6
asdf is offline   Reply With Quote
Old 01-29-2018, 04:49 PM   #6
reeves
If you can't remove it by hand, just wait til the engine/filter is cold.. it'll twist off alot easier. If you can't remove it by hand when it's cold, then it was over-tightened when it was previously put on.
And yes, tighten it 3/4 turn once the filter touches the base is correct.
Old 01-29-2018, 08:37 PM   #7
FirstWinter
Drives: Car
I use this oil filter tool with a ratchet to remove. For tightening I use hand tight + a little bit more.
FirstWinter is offline   Reply With Quote
Old 01-29-2018, 08:39 PM   #8
Bubba says just to stick a screwdriver in it and turn ......
(however, Bubba's hands are so greasy, he can't get a grip on them ..... because he don't use none of those sissy blue shop gloves)
gravitylover (01-30-2018), Tcoat (01-30-2018)
Old 01-30-2018, 08:14 AM   #9
redwine
Appreciate all the responses.
You guys must have strong hand.
The only torque meter i have only goes up to 50 lbf-inc.
(the manual torque setting is 14Nm / 124 Ibf-inc)
Yes, i like the location of the oil filter
Wouldnt bother if its beside the engine sump.
(Dont have Jack Stand & my head cant clear the bottom gap)
I intend to DIY every alternate EO change (by oil pump).
So the wrench will be helpful.
Rgds
Old 01-30-2018, 08:17 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
Well, I don't like to brag... lol.
Having a pump will eliminate the need to even jack up the car and crawl under (although with the Fumoto valve it makes it very easy and quick), I've been thinking about buying one too.
Current DD: M235i
Old 01-30-2018, 12:43 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Fumoto plus ramps (I use Cusco Jack Assists ramps). No tools required
Old 01-30-2018, 01:01 PM   #12
Rgds
Was never a fan of the idea of pumping oil out. You don't get the same flushing effect and it can leave heavier bits and the worst sludge behind. Not that you should have heavier bits nor sludge but just in case...
Old 01-30-2018, 02:57 PM   #13
FirstWinter
Drives: Car
Baller over here I see. I use wood planks from the hardware store. Endless customization with it as well for whatever you need. Don't think my car would make it up most ramps anyways because it's lowered.
Old 01-30-2018, 02:59 PM   #14
Does that come from years of milking cows by hand ...... or masturbation ......??
8RZ (01-30-2018)
TRD Intake Filter Air Filter Cleaner Element FRS BRZ 86 Toyota Racing Development hirollaz Engine, Exhaust, Bolt-Ons 0 03-15-2017 02:46 AM
Consensus on changing whole transmission versus changing solenoids dem00n Engine, Exhaust, Transmission 7 07-20-2016 03:50 AM
upload video of changing filter Dr. BRZ DIY (Do-It-Yourself) Guides 5 11-14-2012 04:27 PM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
