Old 11-13-2012, 07:56 PM   #1
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
upload video of changing filter
im sorry i cant read the pics and the diy guides. i would so much prefer a video that shows it, it would be so much easier to do and understand. if anyone has a video that shows how to, it would be awesome!
Dr. BRZ is offline   Reply With Quote
Old 11-13-2012, 08:50 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Would help if you told folks what filter you're talking about, i.e. oil, air, cabin?
cnk is offline   Reply With Quote
Old 11-14-2012, 12:35 AM   #3
Craig
Craig's Avatar
Drives: Asphalt FRS
He's probably talking Air. I had the same difficulties today. The easiest way to do it is to take the airbox out of the car and install the filter.
I found the perrin filter to be a tad thicker around the edges, making it slightly harder to close the box, gives a better seal around the edges for sure though.
If that doesn't help let me know, I can take some pictures and explain if you need it. A video would be a bit much though.
Craig is offline   Reply With Quote
Old 11-14-2012, 03:59 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
sorry guys i forgot to specify, yes i meant the air filter. i got my HKS filter in yesterday. @ Craig, that would be helpful.
Old 11-14-2012, 04:15 PM   #5
Gen
Drives: Scion FR-S
My first thought was oil and thought it was a joke.
Gen is offline   Reply With Quote
Old 11-14-2012, 04:27 PM   #6
Craig
Craig's Avatar
Drives: Asphalt FRS
I'm going to be installing a zeta intake pipe later this week, when I do it I'll make a DIY filter swap / Intake pipe post.
Probably up by monday/tuesday of next week.
Changing the Horn? mechaghost Cosmetic Modification (Interior/Exterior/Lighting) 21 10-27-2016 12:27 AM
Changing from 1st to 2nd gear noise bazi Engine, Exhaust, Transmission 0 09-23-2012 04:17 PM
changing the side vents? Tylub Cosmetic Modification (Interior/Exterior/Lighting) 1 08-31-2012 08:20 AM
Changing BRZ Badge color computertech01 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-02-2012 10:55 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
