Northern California NorCal
Old 01-30-2018, 06:05 AM   #1
EzyBrzy
Drives: 2015 WRB BRZ
Alignment problem?
I was driving home from work last night and mid way through my commute I start hearing a squeal. The sound was on and off mostly on. Sounded like it was coming from the rear and maybe the tires were rubbing.
The car also wanted to pull to the side really hard randomly. Pulled over to check but didn't see anything out of the normal. Decided to stay off the freeway and take the LONG way home trying to keep it under 40.
Had the alignment done maybe a month ago. Can an alignment just go bad randomly like that or is it a bigger problem?
EzyBrzy is offline   Reply With Quote
Old 01-30-2018, 07:59 AM   #2
jasonojordan
Drives: 2013 satin white brz limited
Alignments "going bad" as you called it is generally caused by hitting large potholes or other objects to jar the car hard enough to change the alignment. Provided you have not hit anything no your alignment should not change once its set unless you do something to change it.
jasonojordan is offline   Reply With Quote
Old 01-30-2018, 08:29 AM   #3
Could have a caliper sticking.
Old 01-30-2018, 10:17 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Did you check your lug nuts? Make sure they are tight
guybo is offline   Reply With Quote
Old 01-30-2018, 11:14 AM   #5
EzyBrzy
Lug nuts are not loose. Co worker riding with me also said it might be the brakes.
The Following User Says Thank You to EzyBrzy For This Useful Post:
Tcoat (01-30-2018)
Old 01-30-2018, 11:17 AM   #6
Could be as easy as changing the pads or a clean and lube of the caliper slides.
EzyBrzy (01-30-2018)
Old 01-30-2018, 11:33 AM   #7
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Had a loud squeel pulling out of my driveway, so promptly pulled back into the garage and jacked it up.
Turns out there was a rock chip stuck inside the caliper body.
Pulled off the caliper and picked the rock out, then re-installed.
Pushed my time line for the day back about half an hour,
but my gosh - sounded like the world was coming to an end.
No permanent damage.
The Following 3 Users Say Thank You to bcj For This Useful Post:
EzyBrzy (01-30-2018), guybo (01-30-2018), Tcoat (01-30-2018)
Old 01-30-2018, 12:14 PM   #8
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Are you on aftermarket wheels/tires or stock?
Originally Posted by humfrz
I'm old and lazy
Old 01-30-2018, 04:34 PM   #9
EzyBrzy
On stockers.
Will pull apart the brakes this weekend when I have time. Well maybe just change them anyways if I'm going through the trouble.
Old 02-07-2018, 02:02 PM   #10
EzyBrzy
Took the day off work since it was going to be slow anyways.
Checked all the brakes and replaced the pads. Rotors were fine.
Still have the problem. Squeaking seem to have disappeared but didn't test drive for too long.
Going to have the alignment checked today. My commute is 50 miles to SF one way and the roads/ramps/speed bumps aren't that great so hopefully it'll fix the problem.
Old 02-07-2018, 02:05 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
Depending on where you are located, AutoRnD in Fremont may be able to sort out your alignment for you.
I'm old and lazy
EzyBrzy (02-07-2018)
Old 02-07-2018, 06:12 PM   #12
EzyBrzy
Went back to the same alignment shop since I had warranty and the guy kept insisting I had something done or installed to the car for the alignment to be that far off the original alignment.
He ended up doing it, but it kind of left a sour taste in my mouth he was accusing me of something I didn't do.
So I guess an alignment can go bad.
Old 02-07-2018, 06:28 PM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
This is why I have lifetime alignments at Firestone. Keeps it in check for daily then when I go to the track I get a proper one done. But if I hit a bad bump it starts to pull or the wheel gets off cencenter no worries getting it fixed
Old 02-07-2018, 06:29 PM   #14
FirstWinter
Drives: Car
I can see the tech's perspective especially after working you get a bit jaded when people try to take advantage of things. But alignments can and do go out of spec from potholes, bumps, etc or techs not torquing down things properly. Shit happens. Either way it's a bit unprofessional to accuse a customer of something especially without evidence. Even if the customer was at fault I find it better to smile and still perform the work. It'll most likely result in a happy and returning customer. Profit in the long run.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
Drift alignment. rear toe problem and front sway bar rubbing trdric Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 09-03-2015 01:21 AM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
TWM short shifter alignment problem aznatama Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-01-2014 10:01 AM
