#85 |
They aren't supposed to fall apart.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | rusty959 (01-23-2018) |
#86 |
Drives: DGM BRZ limited
Looks like I may have found my problem then.
| The Following User Says Thank You to rusty959 For This Useful Post: | Ultramaroon (01-23-2018) |
#87 |
Well now, hang on. You had a p0016, which is bank 1 intake fail.
In your images, I see that the exhaust sprocket failed. Am I seeing that right? Was the plate missing all along?
#88 | |
the 3rd and 4th pictures with "MPL" stamped are the intake, which shows the plate in place and then not in place. Same sprocket in both pictures, the plate was in place when I first took it out, then I gently touched it, and it came off. So far it won't stay back in place. |
| The Following User Says Thank You to rusty959 For This Useful Post: | Ultramaroon (01-24-2018) |
#89 | |
I was sure both had the same plumbing but there aren't any punch marks on the exhaust sprocket.
#90 |
Drives: 2013 BRZ MT
My Subaru shop just called to say that the ECU replacement resolved the P0016 CEL code. Going to grab my car now
| The Following 3 Users Say Thank You to precurse For This Useful Post: |
#91 | |
Drives: 2013 Subaru BRZ
Also, I'm in a predicament... I have the P0016 code pop up early 2017. Replaced Sensor/OCV and ECU (for good measure... brand new one). Code went away. Here's the kicker/dumb moment. I realized after the fact, I changed out the Exhaust (lower) sensor/ocv... Just recently the code has come back, so I switched around the OCV's and sensor on the Intake (top) to see if the code will go away... Nada. Mind you, every time I've gotten the code, my car isn't having idling issues, and seems to be running smoothly. Only mods I have are Headers -> back, Flex fuel kit, and I run E85 90% of the time. I'm at a loss of what to do now, aside from pulling the sprocket. |
#92 | |
I only had idle issues with the turbo kit/tune. My tuner (@DeliciousTuning) wasn't able to get rid of the idle dip/stall, only make it better by raising idle. Didn't realize it could be the cam sprocket until I had already decided to pull the turbo kit. Now that it's off, I haven't seen any idle dip issues, but I've only driven it 40 miles or so, all on the stock tune. If the code comes back when I replace the sprocket I'm going to see if @DeliciousTuning can just disable the code or something on a stage 1 tune, I don't want to lose the EcuTek license on this Ecu. Seems like a dumb CEL anyway. Here is an image which gives you a pretty good idea on what all I had to remove:
#93 | |
#94 | |
Also, I'm guessing there would be a lot of oil drainage? If so, I'd just drain it all and do an oil change afterwards. Not sure if you know or not, but the TSB with placing a shim on the sensor to raise it... where can that shim be purchased? It seems like 1) My timing feels fine 2) Swapped sensors and still having the same code, 3) Swapped OCVs and still same code. 4) Swapped for new ECU Either the timing is off and barely noticeable, or the sensor spacing is throwing it off. I can't think of anything else that's causing my P0016 code. I could try asking my tuner to remove the code, but I feel like that's turning a blind eye to a potential problem down the road. |
#95 | |
I drained my oil before pulling the cover, and once I did that I didn't have very much drain. Throw a pan or some kitty litter below and call it good. No idea on the shim, if it were me I'd probably make my own. You already swapped ECU's? Any chance you swapped in a broken one? I wouldn't count completely out the chance of sprocket being damaged just because it drives fine. If it really is this spring plate thing I can image it being broken just enough that the ecu can correct enough to make it not noticeable for the most part. |
#96 |
Rusty, what did you do with the sprockets you removed?
#97 |
Drives: Firestorm '13
I've been through this ordeal for a similar P0018. One of the cam sprocket broke just like the picture above. They had to replace that and the ECU. At first they just did the sprocket and I drove off the lot no more than a 1/4 mile the light came back on. The ECU must store the code because Toyota told me that the ECU was bad as well (out of spec?) so it had to be replaced. After that, no issues. Mine was MY'13 that were known for this issue. It was still covered under warranty so I paid nothing out of pocket. I remember forgetting the actual costs of the repair lol.
'13 Firestorm
#98 | |
Drives: 2013 BRZ MT
I still find it hard to believe if these two issues are so tightly coupled that they wouldn't just replace the ECU and sprocket together every time. Why give the car back to the customer unfixed? That's horrible customer service.. From the sounds of it, Toyota does the same sort of troubleshooting steps that Subaru does. I would really love to understand the true low-level details about why the ECU gets into this state. Now that warranty is up for the 2013s, a $1200 cam sprocket and a $1700 ECU replacement (what I was quoted) is absolutely absurd. |
| The Following User Says Thank You to precurse For This Useful Post: | ermax (01-28-2018) |
| P0016 fixable without new ECU? | Mr.Jay | Issues | Warranty | Recalls / TSB | 8 | 02-06-2022 05:15 AM |
| P0016/P0017 cause | AVOturboworld | Issues | Warranty | Recalls / TSB | 18 | 04-16-2021 11:09 PM |
| P0016 Code | Shady195 | Engine, Exhaust, Transmission | 30 | 02-21-2019 02:31 PM |
| p0016 need help asap | lol | Issues | Warranty | Recalls / TSB | 25 | 10-30-2018 03:49 PM |
| OFT P0016 and TSB question | mmmcambelsoup | Software Tuning | 10 | 05-24-2017 09:24 AM |
