Old 12-30-2017, 05:50 AM   #897
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by weederr33 View Post
That's sad to hear. I recently got a hold of some Cosworth by Nameless headers so I'm gonna be curious if I'm a victim.
What exhaust are you going to switch to?
if you haven't fitted them yet it may be an idea to cut through the brace as its there to create room on the RHD cars as it prevents the header from 'springing' during the coating process
on a LHD car you have more space
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (12-30-2017)
Old 01-25-2018, 09:18 PM   #898
TxFrs10
TxFrs10's Avatar
Drives: 10 series fr-s
After installing the smaller pulley and driving for a few weeks, I ended up switching to a smaller serpentine belt. 6pk2310. from 91.1" to 91". It would slip on the bottom port side one rib but not come off completely.
Also, a boost leak issue I think we might all have is from the intake tube connection to the stock air box. The clamp dents the plastic of the air box making it difficult to get a good seal if accidentally over tightened, and over time the clamp deforms the plastic.
Third, I cut holes in the metal under tray beneath the headers and it has greatly improved temps. This system doesn't need an oil cooler. Maybe a catch can would be smarter for when a boost leak does occur.
TxFrs10 is offline   Reply With Quote
The Following 4 Users Say Thank You to TxFrs10 For This Useful Post:
ajc209 (05-02-2018), muckypuppy (01-26-2018), nikitopo (01-26-2018), weederr33 (01-26-2018)
Old 01-26-2018, 09:19 AM   #899
Rich196
Drives: GT86
What kind of difference has this made in temps, and its it only the oil temp you have monitored?
Rich196 is offline   Reply With Quote
Old 01-26-2018, 12:56 PM   #900
ajc209
Drives: GT86 Cosworth
I over tightened mine and it deformed the plastic intake pipe. I didnt get a leak though and run it that way for about to year until I got round to fitting and new one when I did the air filter. The clamp has a worm drive so the screw does not need to be tight at all to seal it.
ajc209 is offline   Reply With Quote
Old 01-26-2018, 06:05 PM   #901
TxFrs10
TxFrs10's Avatar
Normal driving I get around 190-195F. Thrashing on the street I don't see much over 210F where as before I could hit 240F with ease. Coolant stays around 174F. No track data yet but I would assume maybe 20-30 degree improvement. I put 4 holes about the size of a playing card.
The Following User Says Thank You to TxFrs10 For This Useful Post:
Rich196 (01-27-2018)
Old 01-27-2018, 10:49 AM   #902
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Have you considered the oem forester oil cooler? More or less to help warm oil up and then regulate it? Curious what your thoughts on it are.
MS, CSCS, TSAC-F, CPT
Old 01-27-2018, 02:04 PM   #903
gahooligan
Drives: 2017 BRZ Premium
Originally Posted by ajc209 View Post
Summit now do a strut brace that fits the cossy! Shown on RHD so may not fit LHD though.
And that still clears the stock hood??
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
The Following User Says Thank You to gahooligan For This Useful Post:
nikitopo (01-27-2018)
Old 01-27-2018, 02:08 PM   #904
gahooligan
Originally Posted by muckypuppy View Post
Mines being going fine Matt. Runs like a dream and torque for days. Sorry i haven't had time to get any logs off to you.
I will be making the switch to a flex tune in the next week or so. Just waiting on some injectors to arrive. I am keen to see how the kit performs with this pulley and E85.
So now that the most awesome Matt at Cosworth got me running with the kit on my 2017 BRZ, i am curious what your impressions of the smaller pully are. Is it enough of a noticable difference to take the extra risk on the rod loading? Love the kit, But I am always interested a little more power.
For the record, I owe Matt a million thanks! You are an awesome dude Matt!
weederr33 (01-27-2018)
Old 01-27-2018, 02:42 PM   #905
weederr33
weederr33's Avatar
Welcome! I'll have to put you on the owners list
The Following User Says Thank You to weederr33 For This Useful Post:
gahooligan (02-11-2018)
Old 01-27-2018, 02:56 PM   #906
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I wouldn't be too much confident to install a strut bar. The hood is quite flexible on high speeds. Even the 90 degree hose at the back of the manifold is rubbing the bonnet. You have to install a small piece of metal on the hood to avoid any problems. You can see this small piece of metal in the picture. I think it is part of the standard installation. I like their SC solution, but they are mainly engine builders and tuners. Meaning they focused basically on this aspect of the car without paying much attention on other areas like handling, weight, chassis strengthening etc. A better solution for my states was their stage 1 products, where there were not many (if any) compromises.
Old 01-27-2018, 09:16 PM   #907
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
The smaller pulley gives a nice little bump in power. It is not a massive gain but levels it out a bit when racing against turbo kitted cars at around 10 PSI. My engine has been blueprinted and balanced whilst being rebuilt under warranty some years ago, and my valve springs have been shimmed etc, so I am not running a factory built engine per se. I have also just switched to Delicious Flex tune, and the car feels great on E85. Now I need to get it on a dyno to see how much has been gained. I am more concerned about the auto box not being able to keep up at this stage haha.
muckypuppy is offline   Reply With Quote
Old 02-05-2018, 09:35 PM   #908
pjp
Drives: frs
Cosworth Suppercharger
Finely Pulled The Trigger !!!
It ships today!!!!!
pjp is offline   Reply With Quote
The Following 2 Users Say Thank You to pjp For This Useful Post:
nikitopo (02-06-2018), weederr33 (02-05-2018)
Old 02-05-2018, 10:31 PM   #909
weederr33
weederr33's Avatar
It ships today!!!!!
YESSSSSSSSSSSS!!
I'll add you to the owners list
Old 02-17-2018, 12:22 PM   #910
pjp
Drives: frs
Supercharger Install
Box Just ARRIVED !!!
Torque wenches out for calibration.
How long did it take to install yours ?
Thanks
The Following User Says Thank You to pjp For This Useful Post:
weederr33 (02-17-2018)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 09:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 02:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
