Old 01-25-2018, 06:11 PM   #1
eddwvrd
Drives: Frs
CAI mod
I was thinking of getting a k&n cold air intake. Do i need to take off the negative terminal before installation? I heard that the car would run lean and some has their check engine lights on. I also read in the other forums that you need to get it tune?
eddwvrd is offline   Reply With Quote
Old 01-25-2018, 06:12 PM   #2
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Instructions come with kits, just follow what the manufacturer reccomends during install.
Old 01-25-2018, 06:13 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Save your money, just an inlet tube and drop-in filter.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-25-2018, 06:38 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Both of these answers are correct... specially stock is good as is.
Old 01-25-2018, 06:49 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Inlet tube and K&N drop in just installed. I waited till I got both for under a hundred.
I LIKE TIRES!
Old 01-25-2018, 07:42 PM   #6
You do not need a tune and the car should not run lean from a simple intake change. You don't need to disconnect the battery but it never hurts to do it anyway when working with the electronic parts.
Old 01-25-2018, 09:49 PM   #7
eddwvrd
Drives: Frs
Thank you so much now i dont need to spend a lot loll. What brand of inlet tube should i get?
Old 01-25-2018, 09:51 PM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Maf calibration?
Old 01-26-2018, 02:42 AM   #9
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Maf calibration?
Will 100% be needed if you get the K&N Typhoon Intake.
Trueweltall is offline   Reply With Quote
Old 01-26-2018, 05:49 AM   #10
https://www.perrin.com/shop/air-indu...e-for-fr-s-brz
Old 01-26-2018, 10:42 AM   #11
tennisfreak
Drives: 2018 BMW M240i
Is the inlet tube going to get me anything other than looks?
Old 01-26-2018, 10:45 AM   #12
8RZ
The Gunshine State
8RZ's Avatar
Wider diameter and smoother airflow.
Current DD: M235i
Old 01-26-2018, 10:45 AM   #13
There is a huge debate on that. The manufactures claim 2 to 5 HP but that does not seem realistic. You are still just moving air and the very small change in volume and flow really shouldn't have any measurable impact. Of course many people that do it say the "feel" an improvement but placebo effect can be strong.
OK pro tube guys you're up...
Old 01-26-2018, 11:00 AM   #14
Jordanwolf
Rice King
Jordanwolf's Avatar
That Subaru badge isn't centred.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
