-   -   CAI mod (https://www.ft86club.com/forums/showthread.php?t=124927)
eddwvrd 01-25-2018 06:11 PM
CAI mod
I was thinking of getting a k&n cold air intake. Do i need to take off the negative terminal before installation? I heard that the car would run lean and some has their check engine lights on. I also read in the other forums that you need to get it tune?
Summerwolf 01-25-2018 06:12 PM
Instructions come with kits, just follow what the manufacturer reccomends during install.
8RZ 01-25-2018 06:13 PM
Save your money, just an inlet tube and drop-in filter.
ichitaka05 01-25-2018 06:38 PM
Both of these answers are correct... specially stock is good as is.
Leonardo 01-25-2018 06:49 PM
Inlet tube and K&N drop in just installed. I waited till I got both for under a hundred.
http://www.ft86club.com/forums/pictu...ictureid=11230
Tcoat 01-25-2018 07:42 PM
You do not need a tune and the car should not run lean from a simple intake change. You don't need to disconnect the battery but it never hurts to do it anyway when working with the electronic parts.
eddwvrd 01-25-2018 09:49 PM
Thank you so much now i dont need to spend a lot loll. What brand of inlet tube should i get?
Spuds 01-25-2018 09:51 PM
Maf calibration?
Trueweltall 01-26-2018 02:42 AM
Originally Posted by Spuds (Post 3034017)
Maf calibration?
Will 100% be needed if you get the K&N Typhoon Intake.
Tcoat 01-26-2018 05:49 AM
https://www.perrin.com/shop/air-indu...e-for-fr-s-brz
tennisfreak 01-26-2018 10:42 AM
Is the inlet tube going to get me anything other than looks?
8RZ 01-26-2018 10:45 AM
Wider diameter and smoother airflow.
Tcoat 01-26-2018 10:45 AM
There is a huge debate on that. The manufactures claim 2 to 5 HP but that does not seem realistic. You are still just moving air and the very small change in volume and flow really shouldn't have any measurable impact. Of course many people that do it say the "feel" an improvement but placebo effect can be strong.
OK pro tube guys you're up...
Jordanwolf 01-26-2018 11:00 AM
That Subaru badge isn't centred.
