Old 01-25-2018, 12:21 PM   #1
Bread1
Drives: Scion Frs
Should I get 17x9 w 40 off or 18x8.5 w 44 off both konig dekagram
Bread1 is offline   Reply With Quote
Old 01-25-2018, 12:36 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
17x9.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Clipdat (01-25-2018)
Old 01-25-2018, 12:40 PM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
17x9 w/ 245/40, if your suspension can fit it! One of my favorite mods that I've done.
Originally Posted by 8RZ View Post
17x9.
Originally Posted by humfrz
I'm old and lazy
8RZ (01-25-2018)
Old 01-25-2018, 12:43 PM   #4
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
You buying for...? Performance? Looks? & how's the tire budget option?
Old 01-25-2018, 02:09 PM   #5
Bread1
Drives: Scion Frs
17x9.
Will they fit stock suspension?
Old 01-25-2018, 02:10 PM   #6
Bread1
Drives: Scion Frs
A little of both and around 500
Old 01-25-2018, 02:19 PM   #7
ichitaka05
Site Moderator
ichitaka05's Avatar
Hm... then that's a tough, cuz both size can fit 245~265 width tires, but 18's will cost more than 17's.
If you're in the tight budget, but want some kind of performance plus the looks, recommend going w 17x8 with offset 30~40 and get 225/45-17 tires. You can get decently cheap, but not bad performance tires. Just you might not like that, tires aren't wide as 245 or 265... but overall performance are good.
I'm currently running 18x8 +35 w 225/40-18 tires and it's good daily setup
But I kinda miss lightness and steering feel of 17's, so prob be going back to 17x8 +35 w 225/45-17 setup for daily again.
Old 01-25-2018, 02:25 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
ichitaka05: but are your memories of 17x8+35, or of stock, of narrower & deeper offset? As in, if lightness was about how easy to turn wheel, maybe it was easier with stock wheels due less scrub radius, not so much wheel/tire weight .. so wondering, if width & offset will stay same, if you'll get what you wished ..
Old 01-25-2018, 03:01 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Both wheels are Type "A" face or less concave. So that doesn't factor in...
The website I looked at had the 17x9's at $707 and the 18x8.5's at $815 a set.
The 17x9 +40 will only have approx. 5-6mm of clearance to the spring perch. The 18x8.5 will only have 2.4mm more of clearance.
The 18.8.5+44 is considered flush in the front at stock height. The 17x9 will poke 10mm comparatively to the 18.
I would either go 225/45 or 245/40 for the 17's. For 18's I'd go 225/40 or 245/35 ( For some reason I'm not a fan of 235's.., unless 235/40/17)
I LIKE TIRES!
Old 01-25-2018, 03:17 PM   #10
ichitaka05
Site Moderator
ichitaka05's Avatar
I had 17x8 +40ish w 225/45-17 before my current 18’s & weight deference between these 2 were +-4 lbs per wheel (+Tires) making 18’s heavier. I do have stock wheels, which I’m using for winter set. Comparing old 17’s to stockers, aftermarket wheels were heavier cuz it’s wider (wheel +1” & Tires +10mm), but we’re talking bout less than .5 lbs difference. & steering feel wasn’t different as much as 18’s. Of course I had a bit more grippy tires than stock, but nothing crazy difference
Old 01-25-2018, 04:19 PM   #11
toast
Drives: 14 BSP Edelbrock BRZ
If you don't get more dish on 9" wide tires I would go 17x8 with 225 tires. I have 17x9 with 245 and it is just overkill. Only reason I did the 9 is because in my wheel all the extra width appeared in the concavity of the face and made it much sexier.
toast is offline   Reply With Quote
Old 01-25-2018, 05:06 PM   #12
Bread1
Drives: Scion Frs
What wheels are you running?
Old 01-26-2018, 11:36 AM   #13
toast
Rota Titan 17x9e42. The 17x8 version is just over 15 lbs, but you lose almost all the dish.
Supercharger goes on soon so hopefully I will need the extra grip
The Following User Says Thank You to toast For This Useful Post:
Leonardo (01-26-2018)
Old 01-26-2018, 12:26 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
The 17x9 Titans look amazing. Nice choice. I thought you were going to say RPF1 because the 9" are better looking than the 8". Titans are a great balance of cost, weight, and looks. They were on my short list of wheels.
I LIKE TIRES!
Konig Oversteer 18x8 + 18x9 Leonardo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 10-05-2018 10:59 AM
Bronze konig Hypergram 18x8.5 +38 86socal Wheels and Tires 0 08-11-2017 11:08 PM
Critique my Decision Rota Titans 18x8.5 +45 VS. Konig Rennform 18x8 +40 SuperTom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 05-23-2017 03:03 PM
Konig Control 18x8+45 ArrowManXIV Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-09-2015 10:19 PM
Konig Torch 18x8.0 +35 khan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-21-2014 12:27 AM
