Old 01-25-2018, 11:31 AM   #1
Brink
Drives: 2017 BRZ
Rear sway bar bolts torque?
Can anyone tell me what the rear sway bar bolts are supposed to be torqued to? I'm planning to install a Driveway Labs diffuser in the next day or two hopefully, and I need to loosen/remove these bolts to do it and I can't find what they're supposed to be torqued to.
Brink is offline   Reply With Quote
Old 01-25-2018, 12:58 PM   #2
Somerandom18
Drives: 2017 manual BRZ
Looks like 44 ft-lbs
http://www.ft86club.com/forums/showthread.php?t=85760
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Brink (01-25-2018)
Old 01-25-2018, 01:03 PM   #3
FirstWinter
Drives: Car
Which ones? The ones connecting to the endlink or the ones with the bracket connected to the subframe?
FirstWinter is offline   Reply With Quote
Old 01-25-2018, 01:25 PM   #4
Brink
Drives: 2017 BRZ
These 2.
Old 05-28-2018, 08:29 PM   #5
jmimac351
Chin Chief Instructor
jmimac351's Avatar
Drives: 2015 Ford F150 Aluminium Couch
Stumbled across this thread and thought this might save others the hassle... see the picture attached of torque values for rear sway bar. The torque for the bolts on that bracket is 22 ft/lbs, not 44.
The guy in this video below likely looked at the first value listed... "30". That's not "ft/lbs", which I'm guessing it what he looked at, and he stripped the backing nut. See the legend at the bottom, the last number listed in parenthesis is the "ft/lbs" value.
2015 Subaru BRZ
2008 NC Miata with 2.5 swap
Building 1963 289 Cobra Le Mans Replica
Cobra Replica Build Pics
Chin Chief Instructor www.ChinTrackDays.com
jmimac351 is offline   Reply With Quote
Rear sway bar bracket bolts Somerandom18 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-10-2017 11:03 AM
Driveshaft bolts torque oliverc Engine, Exhaust, Transmission 1 11-06-2015 12:29 PM
torque specs for front and rear subframe bolts mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-17-2015 03:54 PM
WTB - OEM Sway Bar Reinforcement Plates and Stabilizer bar bolts loading_please_wait Want-To-Buy Requests 0 06-16-2015 01:58 AM
FS: SPC Rear LCAs, SPC Camber Bolts, Eibach Sportline Springs & Sway Bars, Bilsteins BRZZZZZZZZZZ Canada Classifieds 7 03-20-2014 01:16 AM
