#841 |
My VTEC fluid is full
Drives: EFF JAY
So the leather (or vinyl) on my steering feel is starting to peel. I was thinking of replacing it with a TRD wheel, which carries over the OEM airbag and other components.
Would this be a performance modification and therefore illegal in SSC? Or does it fall under cosmetic? |
#842 | |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My wife and I are members of the hosting club in Ft Myers (GCAC) and will not show up on registration till the last minute. (Whole club is registering on site) - so the pro solo is already at 5 for SSC and the match is at 4. |
#843 | |
Drives: 23 BRZ
I'll still post a co-drive feeler on the FB group for Ft Myers, I don't need to be at that one, but want at least one drive in an SSC car this spring before I decide. |
#844 | |
Drives: 2014 FR-S SSC
-Eric K - Milwaukee Region SCCA - 2014 FR-S
#845 |
Drives: EFF JAY
#846 | |
Drives: 2013 Firestorm FR-S
I will say, the TRD wheel is pretty sweet though. I really want one, but can't justify the cost.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#847 | |
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
--kC
K. Casey | NER SCCA | SSC - '14BRZ For Sale
#848 | ||
Drives: '15 STX
#849 |
Drives: BRZ 2017 Pure Red, MT
One could argue that the spirit of the rule is only to prevent someone from removing the airbag, or mess with it and risk getting injured. Because if the steering wheel doesn't have an airbag, then you can change it. But if you follow the rule to the letter, then you can't.
"D. Alternate steering wheels are allowed, provided the outside diameter is not changed by more than one inch from the standard size. Steering wheels with an integral airbag may not be changed." |
#850 | |
Drives: '15 STX
I would write a letter for clarification. |
#851 |
Drives: EFF JAY
ok I get it about the TRD wheel. But you have to run the same year? 13-16 BRZ/FRS are the same. I have a 14 so i’d have to put a 14 wheel? How do I even check for that?
#852 |
Drives: EFF JAY
or did you mean same generation? i.e 13-16 vs 17+
#853 | |
Drives: '15 STX
Honestly I think the TRD wheel should be able to be used, but given there are a ton of snowflakes in this class I would definitely be legal to the letter. |
#854 |
Drives: Miata
Yep. You should replace your wheel with one that has the same part number. If you replace the wheel with anything else you risk being protested. (IMHO: it'd be a weenie protest, but I bet it would be upheld.)
| Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) | OnionTou | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 55 | 07-01-2016 01:36 AM |
| what's the difference between twin screw, centrifugal, single turbo and twin turbo? | warplane95 | Forced Induction | 86 | 04-17-2014 02:36 PM |
| my twin | RWDGUY | Mid-Atlantic | 2 | 04-08-2013 09:23 PM |
| JDM Spec-C V9 Twin Scroll VF36 complete | Nico TURBO | Engine, Exhaust, Bolt-Ons | 0 | 12-05-2012 11:20 AM |
