Old 12-11-2017, 03:07 PM   #4523
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
New topic (I assume..)... I'm looking for some cheap timing options for HDPE days, emphasis on 'cheap'. I don't need world class gear - just something reasonably and repeatably accurate. I don't have a smartphone so, no GPS gear. Are there inexpensive transponders/receivers available for this, or am I stuck with pushing buttons on my wristwatch? TBH, I normally don't mind that so much but my last event was in the rain and there was a lot of standing water, so my focus was on keeping the car between the walls, not on fumbling around for a button on my watch...lol.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-11-2017, 03:18 PM   #4524
CSG Mike
CSG Mike's Avatar
Cheapest is use what you got. In this case, a watch.
You can buy old smart phone for $50 or less, and use that.
Old 12-11-2017, 03:54 PM   #4525
venturaII
venturaII's Avatar
Wonder how well this would work...15 meters isn't very far, but the transmitter could be set on top of the outside pit wall, or any wall close to the track I suppose..
https://www.ebay.com/itm/V3-Best-Lap...4383.l4275.c10
Old 01-24-2018, 01:22 PM   #4526
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
How many track days does everyone go between diff fluid changes? If you DD it how many street miles with said track days
finch1750 is online now   Reply With Quote
Old 01-24-2018, 01:53 PM   #4527
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
I go 15-20 track days between diff oil changes.
Works well for me
Fish Eagle is offline   Reply With Quote
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
finch1750 (01-24-2018), Icecreamtruk (01-25-2018)
Old 01-24-2018, 03:06 PM   #4528
Pat
Pat's Avatar
Drives: 2023 BRZ
I change tranny and diff fluids at the end of every track season. For me that works out to be about 15,000 miles and 12 track days.
The Following 4 Users Say Thank You to Pat For This Useful Post:
finch1750 (01-24-2018), Icecreamtruk (01-25-2018), Lynxis (03-12-2018), Ultramaroon (01-24-2018)
Old 01-24-2018, 05:54 PM   #4529
CSG Mike
CSG Mike's Avatar
What kind of diff are you on, and what fluid do you use? Any other diff modifications?
Old 01-24-2018, 06:13 PM   #4530
finch1750
finch1750's Avatar
Motul. Oem diff with no mods to it
Old 01-24-2018, 07:47 PM   #4531
CSG Mike
CSG Mike's Avatar
Unless you're cooking the fluid, every 5 track days would be considered very conservative.
Old 01-25-2018, 12:22 AM   #4532
GibbsFRS
What's the latest word on running old cars (April 2012 build date to be exact) on the track, in regards to reliability?
Planning to start with an OFT stage 1 tune and an oil cooler. Are these enough to keep my car relatively safe (stock engine, aside from possibly headers as well)?
GibbsFRS is offline   Reply With Quote
Old 01-25-2018, 04:04 PM   #4533
CSG Mike
CSG Mike's Avatar
Get a newer car if able.
Old 01-25-2018, 11:30 PM   #4534
GibbsFRS
If not, what can I expect/what can I further do to make the car bulletproof? I plan on doing regular track days + some time attack (don't need an endurance build, just enough for 15-20 min sessions max).
Old 01-26-2018, 12:14 AM   #4535
CSG Mike
CSG Mike's Avatar
Replace your entire powertrain with a 14+ powertrain, but it'll cost you more to do that, then to just get a newer car.
Old 01-26-2018, 07:30 AM   #4536
ryejeff
Drives: Miata
At the risk of rehashing old/well-known content, will you elaborate?
You responded pretty strongly with a sentiment to get a newer car. I thought I heard (but I'm not an expert) that later 2013 cars included fixes. Is there any 2013 that would be acceptable? If so, how would I recognize a 2013 that was built late enough?
I was under the impression that the early build date 2013s suffered from a few things that were fixed. Are these the problems that make you recommend a 2014+? Are there additional things I'm missing?
  • Weak TOB (aside: was this ever fixed? when?)
  • Coil packs prone to heat problems (again, when was this fixed, if ever?)
  • Fuel filler hose internal collapse
  • Moisture intrusion into taillights (though I wouldn't expect this to cause a problem on track)
I am hoping to get a twin at some point and want to make sure I get the best fit for my intended use. Thanks for the info!
ryejeff is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
