Old 01-24-2018, 09:47 AM   #15
Jordanwolf
Rice King
Jordanwolf's Avatar
Originally Posted by Riftur View Post
Everyone keeps stating that I do not understand what max PSI stands for. Please stop with this.
kinda your own fault
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 01-24-2018, 09:51 AM   #16
Riftur
Riftur's Avatar
3 people is this thread actually answered the question. The rest felt they needed to feel superior by implying I do not know what max means. If it makes you all feel better about yourselves more power to you. Its just sad. Tcoat, Dowroa and Twinz thanks for the real advice.
Riftur is offline   Reply With Quote
The Following User Says Thank You to Riftur For This Useful Post:
dowroa (01-24-2018)
Old 01-24-2018, 09:52 AM   #17
Riftur
Riftur's Avatar
Why were you running 43 psi when the recommended pressures for the car are 35? I think everyone is just confused as to that part since it's not making logical sense, unless you have very strange tires?
On stock tires, 35 psi cold increases to 38psi hot with normal street driving by my observation. Ideally a different tire of the same size would be at 38 hot as well (again, street use only, and doesn't account for differences in structure). However, you actually have a wider tire than stock, so I would think it would be better to run a slightly lower hot tire pressure to maintain the appropriate contact patch.
Something else to keep in mind, lower pressures heat the rubber up more. Hotter rubber usually means more grip and more wear.
They are not stock tires and rims. Did you miss this?
Old 01-24-2018, 10:00 AM   #18
Jordanwolf
Rice King
Jordanwolf's Avatar
It's the internet though. I think you are taking it way too personal lol, no one is assuming your gender so chill.
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
Brayden_23 (01-24-2018)
Old 01-24-2018, 11:20 AM   #19
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Please read the whole post you quoted. I said you had wider tires than stock. I then stated that meant I would want to run a slightly lower tire pressure than stock if in the same situation.
I'm asking because there was perhaps something else I am missing as to why somebody might increase tire pressure. Either you had a good reason or didn't. Usually I ask questions assuming the former. Your responses thus far have indicated the latter.
Old 01-24-2018, 11:34 AM   #20
stevesnj
stevesnj's Avatar
These are the first tires I ever bought with such a high max PSI. I never had any of my tires over 35 before these. I will lower it back down to 38 and see if that makes a difference. Thanks for the suggestions.
Check for wear on the center of the tire, this happens with over inflation.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
dowroa (01-24-2018), Tcoat (01-24-2018)
Old 01-24-2018, 11:36 AM   #21
stevesnj
stevesnj's Avatar
Tire pressures are determined by vehicle weight. Width or height shouldn't have any determination of the tire pressure.
Old 01-24-2018, 12:09 PM   #22
TommyW
TommyW's Avatar
Drives: '13 Whiteout
You can cure most handling issues with tire pressure. Front and rear can be different if necessary
TommyW is offline   Reply With Quote
Old 01-24-2018, 12:28 PM   #23
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Get the car aligned if you still feel the car is loose after changing the tire pressure. Get some toe-in the rear.
ineedyourdiddly
Old 01-24-2018, 12:33 PM   #24
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
In short, start with the OEM tire pressures.
Are you still running the stock dampers and springs? Stock rear sway?
The tires that you selected:
* https://www.tirerack.com/tires/tires...GTZ+All+Season
Has reviews like...
Ok dry traction and overall driving comfort. Wet traction very bad. Back end slides out easily in wet corners. Will try something different in the future.
I personally don't have experience with this tire and I personally find 400TW tires to be pretty bad in grip (especially in cold weather). Granted, the 200TW tires I run are equally bad in the cold and don't operate well under 40*F.
Since that is a UHP Summer and I put you in as living in Sebring, FL, they should be working well now in the dry (70*F).
Any other inputs you can give us?
Else, we can all supply to you other tires to look at.
Still, start with COLD pressures on the door and re-attmempt.
Let us know the environment variables and conditions where it is not performing well.
In short, they could just be crap tires.
I can state they would not be my first choice living in FL or even living here in NC.
Let us know if there is more we can help with, but give us specifics.
The devil is always in the details.
Thanks.
dowroa is offline   Reply With Quote
The Following User Says Thank You to dowroa For This Useful Post:
Spuds (01-24-2018)
Old 01-24-2018, 12:36 PM   #25
40 degrees.
In Florida where that is very unusual.
Even at proper inflation on the best of tires they are going to feel very strange to him.
Spuds (01-24-2018)
Old 01-24-2018, 12:39 PM   #26
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Set them to 33-35 all around and move on with life. Also get different tires next time because those are junk, imo.
Originally Posted by humfrz
I'm old and lazy
Adam_L (01-25-2018)
Old 01-24-2018, 01:04 PM   #27
I had those same tires on one of my Lancers. Hated them. Even for all seasons they somehow managed to be way too soft in the summer and too hard in the winter. The good part was they wore out really, really fast.
Clipdat (01-24-2018), Spuds (01-24-2018)
Old 01-24-2018, 01:07 PM   #28
Clipdat
Proud of BOXER
Clipdat's Avatar
The only thing I like about them is the name. Sounds cool. Tiger paw! Rawr!
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Leonardo (01-24-2018), Ultramaroon (01-24-2018)
Am I the only one that feels bothered by this (R.S 1.0) 1GiantTurtle Scion FR-S / Toyota 86 GT86 General Forum 22 12-11-2014 08:18 PM
Rear LCA Install Help/Something feels off srizzors25 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 10-28-2014 10:52 PM
18's or 19's ... What looks and feels best on FR-S. Jon1084 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 65 07-19-2013 06:42 PM
Everything else feels like driving a bus! BRZnut BRZ First-Gen (2012+) — General Topics 42 01-21-2013 08:30 PM
Feels like christmas! yeabude BRZ First-Gen (2012+) — General Topics 3 06-11-2012 01:59 PM
