#15 |
Rice King
kinda your own fault
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#16 |
3 people is this thread actually answered the question. The rest felt they needed to feel superior by implying I do not know what max means. If it makes you all feel better about yourselves more power to you. Its just sad. Tcoat, Dowroa and Twinz thanks for the real advice.
| The Following User Says Thank You to Riftur For This Useful Post: | dowroa (01-24-2018) |
#17 | |
#18 | |
Rice King
Glorious Honda.
| The Following User Says Thank You to Jordanwolf For This Useful Post: | Brayden_23 (01-24-2018) |
#19 |
The Dictater
Drives: '13 Red Scion FRS
Please read the whole post you quoted. I said you had wider tires than stock. I then stated that meant I would want to run a slightly lower tire pressure than stock if in the same situation.
I'm asking because there was perhaps something else I am missing as to why somebody might increase tire pressure. Either you had a good reason or didn't. Usually I ask questions assuming the former. Your responses thus far have indicated the latter. |
#20 |
Check for wear on the center of the tire, this happens with over inflation.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#21 | |
#22 |
Drives: '13 Whiteout
You can cure most handling issues with tire pressure. Front and rear can be different if necessary
#23 |
Drives: '13 FRS - STX
Get the car aligned if you still feel the car is loose after changing the tire pressure. Get some toe-in the rear.
#24 | |
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
In short, start with the OEM tire pressures.
Are you still running the stock dampers and springs? Stock rear sway? The tires that you selected: * https://www.tirerack.com/tires/tires...GTZ+All+Season Has reviews like... Quote:
Since that is a UHP Summer and I put you in as living in Sebring, FL, they should be working well now in the dry (70*F). Any other inputs you can give us? Else, we can all supply to you other tires to look at. Still, start with COLD pressures on the door and re-attmempt. Let us know the environment variables and conditions where it is not performing well. In short, they could just be crap tires. I can state they would not be my first choice living in FL or even living here in NC. Let us know if there is more we can help with, but give us specifics. The devil is always in the details. Thanks. |
| The Following User Says Thank You to dowroa For This Useful Post: | Spuds (01-24-2018) |
#25 | |
In Florida where that is very unusual. Even at proper inflation on the best of tires they are going to feel very strange to him.
| The Following User Says Thank You to Tcoat For This Useful Post: | Spuds (01-24-2018) |
#26 | |
Proud of BOXER
Drives: Subaru Boxer
Set them to 33-35 all around and move on with life. Also get different tires next time because those are junk, imo.
| The Following User Says Thank You to Clipdat For This Useful Post: | Adam_L (01-25-2018) |
#27 |
I had those same tires on one of my Lancers. Hated them. Even for all seasons they somehow managed to be way too soft in the summer and too hard in the winter. The good part was they wore out really, really fast.
#28 | |
Proud of BOXER
The only thing I like about them is the name. Sounds cool. Tiger paw! Rawr!
| The Following 2 Users Say Thank You to Clipdat For This Useful Post: | Leonardo (01-24-2018), Ultramaroon (01-24-2018) |
| Am I the only one that feels bothered by this (R.S 1.0) | 1GiantTurtle | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 12-11-2014 08:18 PM |
| Rear LCA Install Help/Something feels off | srizzors25 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 10-28-2014 10:52 PM |
| 18's or 19's ... What looks and feels best on FR-S. | Jon1084 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 65 | 07-19-2013 06:42 PM |
| Everything else feels like driving a bus! | BRZnut | BRZ First-Gen (2012+) — General Topics | 42 | 01-21-2013 08:30 PM |
| Feels like christmas! | yeabude | BRZ First-Gen (2012+) — General Topics | 3 | 06-11-2012 01:59 PM |
