#15 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| The Following User Says Thank You to Jordanwolf For This Useful Post: | humfrz (10-30-2017) |
#16 |
Thanks for that ........
After reviewing your case, I still believe that a part of the exhaust system (including the heat shield) is rattling on another part of the car. I figure this is happening when the engine is torqueing over (yes, this engine does have torque ..... ).This engine is quite wide and I understand the motor mounts are quite giving ..... so, a slight bit of torqueing (twisting of the engine) could move the outer parts of the engine quite a bit (relatively speaking), allowing the exhaust to touch something else. So, what to do. It sounds like plan A (taking it to a dealer) is not working for you. DIY may not be the best plan because of you don't have a rack. I would recommend plan C. That would be to take your car into an old time automotive shop that has some experienced mechanics with some common sense (automotive wise) and see if they can figure out what is making the noise ...... and fix it. Back-in-the-day ....... ....... I would have put the car up on a rack at my uncles auto shop, figured which way the engine twisted under load, and looked for any part of the exhaust system that even came close to touching something else, ...... then, with my trusty crow bar, pried it away from that part and stuck a wooden wedge in there.When I found the culprit, I would wire that sucker over so it didn't hit anymore (and take the wedge out). Good hunting! humfrz |
#17 | |
Drives: Gts86
Is your problem the same as the one from the clip. If thats the case, I have it too. I manage to get rid of the sound by pluggin the sound tube but I havent figure out the root cause yet. |
#18 | |
Rice King
I've still been in contact with Toyota about it, but they are taking their sweet ass time. They even got me to send them a sound clip... which I have no problem doing something to help fix my car, but out of the 4 or 5 times they've had it, they couldn't think to record then.. -_-
Glorious Honda.
#19 | |
Drives: Gts86
#20 | |
Rice King
This video almost seems like it is always making that noise (or the issue is a lot worse), where mine isn't always making that noise, but the sounds are very similar and I can recreate it basically at will with something like a 66% success rate on level ground (100% uphill, 20% downhill). I have a sound clip, but I don't think this forum supports audio clips :/
Glorious Honda.
| The Following User Says Thank You to Jordanwolf For This Useful Post: | howareyoukk (01-24-2018) |
#21 | |
Drives: Gts86
| The Following User Says Thank You to howareyoukk For This Useful Post: | Jordanwolf (01-24-2018) |
#22 |
Not pro yet
Drives: 2020 Toyota GT86
Hi guys, reviving a old thread again and I am sorry. Recently I am having the same issue. My one is automatic and it has now 1750 KM on ODO, completely stock. In short, i can hear metallic rattle sound once i come to a complete stop after driving on motorway, then when I pressed throttle lightly and around 2000-3000 rpm. Its funny, if i come to a complete stop and wait 2-3 mins, then i drive, no sound.
Anyway, finally I have found a thread similar to my issue. What is the update now? It got fixed? Or I have to live with it? |
#23 | |
Rice King
I can't remember if I said in my updated, but I actually had a chance to drive a demo car and was able to manipulate it into doing the exact same sound, so it may actually be a trait with these cars as odd as that is to say. The entire time driving it, nothing ever seemed to feel or appear different, so I just adjusted my driving. I wouldn't be too concerned, especially if it's only within a specific rpm range, but if it begins to worsen, then I suggest looking into it beyond what I have. Also the difference between AT and MT may show something in the long run, but I'm no Toyobaru engineer.
Glorious Honda.
| The Following User Says Thank You to Jordanwolf For This Useful Post: | alone1i (09-03-2020) |
#24 |
Not pro yet
I am not a car guy. Hopefully this car will make me better in this field. Thanks for the update.
| washing machine rattling sound on WOT | alchemis | Engine, Exhaust, Transmission | 18 | 09-19-2018 01:34 AM |
| Rattling sound from front right side of car. | vramsaran | Issues | Warranty | Recalls / TSB | 14 | 05-07-2018 10:09 PM |
| Rattling Sound In Neutral | tekFRS234 | Issues | Warranty | Recalls / TSB | 5 | 07-16-2015 11:23 AM |
| gearbox rattling sound at high RPM | rennlistuser3 | Issues | Warranty | Recalls / TSB | 9 | 07-07-2015 07:29 PM |
| New rattling sound at idle | IAmNotTheDriftKing | Issues | Warranty | Recalls / TSB | 20 | 10-24-2014 03:33 PM |
