Old 01-23-2018, 11:55 PM   #15
Zentec
Drives: 2017 Toyota 86
Originally Posted by stevesnj View Post
I use 0w-20 in the winter and 5w-30 in the summer here in New Jersey in the USA
Good man. But with all those toll booths in Jersey the 30 is better protection for ya lol. Gets costly too.
Zentec is offline   Reply With Quote
The Following User Says Thank You to Zentec For This Useful Post:
stevesnj (01-24-2018)
Old 01-23-2018, 11:58 PM   #16
Zentec
Originally Posted by Tokay444 View Post
I split the difference and 0w-40 year round.
It actually starts or do you have a oil warmer it gets cold up there. If your Molsen xxx beer freezes you need to turn the oil warmer on.
Old 01-24-2018, 08:20 AM   #17
Tokay444
0 is zero is 0...
The Following User Says Thank You to Tokay444 For This Useful Post:
Zentec (01-24-2018)
Old 01-24-2018, 11:23 AM   #18
stevesnj
stevesnj's Avatar
Well, now, that's old school fer sure ...... 20 weight in the winter ..... 30 weight in the summer ......
I take the car to the track during the summer so it covers all bases.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
humfrz (01-24-2018)
Old 01-24-2018, 11:53 AM   #19
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
Originally Posted by Ernest72 View Post
no need for anything more than a good 0W20, unless you are tracking, autox, etc. maintain level and intervals and you are good to go.
Say you are planning on doing several autoX and a few trackdays in the summer.. What should I use instead of 0W-20?
TorontoNat is offline   Reply With Quote
Old 01-24-2018, 12:36 PM   #20
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I use PUROL 10-40 year round. I live in southern CA so it's warm all year. After 50,000 miles, supercharged on e-85 with several dozen track days I pulled the engine for a blown head gasket. Of course I checked the bearings and they looked good as new. I'm very pleased with PUROL.
Lunatic is offline   Reply With Quote
Old 01-24-2018, 01:11 PM   #21
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I run 0w30 year round here in Ca for about 4 years and 50k. Next oil change I'm going to get a used oil analysis to check and post it on the forum. I would love to see the used oil analysis for other oil weights in different climates/conditions.
DandoX is offline   Reply With Quote
Old 01-24-2018, 01:14 PM   #22
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
If you're going to switch to a heavier warm weight, why keep the 0 cold weight?
Originally Posted by humfrz
I'm old and lazy
Old 01-24-2018, 01:59 PM   #23
DandoX
Senior gif poster
DandoX's Avatar
I'm waiting to see the results of the use oil analysis. I switched from 0w20 to 0w30 because I wanted more protection in hotter months. Also I was following Mobil 1s recommended oils for the FA20. I think it may have less wear on start up when it's like 2degrees Celsius out which it gets to sometimes in the foothills where I live. Depending on the use oil analysis I may switch to 5w30. I'll post the results on the next oil change.
Here is a related thread about a 0w30 used oil analysis: http://www.ft86club.com/forums/showthread.php?t=122925
Last edited by DandoX; 01-24-2018 at 02:07 PM. Reason: Added link to relevant thread
Old 01-24-2018, 02:18 PM   #24
Tokay444
For cold starts.
Old 01-24-2018, 02:19 PM   #25
Clipdat
Proud of BOXER
Clipdat's Avatar
For cold starts.
I'm old and lazy
Old 01-24-2018, 02:20 PM   #26
Tokay444
" I think it may have less wear on start up when it's like 2degrees Celsius out which it gets to sometimes in the foothills where I live."
Old 01-24-2018, 02:22 PM   #27
Clipdat
Proud of BOXER
Clipdat's Avatar
Right, which isn't even freezing.
I'm old and lazy
Old 01-24-2018, 02:23 PM   #28
Tokay444
Which is 2 degrees above freezing.
Alternate way to open hood Bjack21 Issues | Warranty | Recalls / TSB 21 02-06-2017 08:01 AM
Alternate center caps for RPF1? JGalp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 05-13-2016 12:49 AM
An alternate to OEM Audio + that's actually affordable BMHumanic Electronics | Audio | NAV | Infotainment 24 02-28-2014 06:28 PM
DIY - Alternate Hood Prop F1point4 DIY (Do-It-Yourself) Guides 13 03-20-2013 10:22 PM
Alternate car? ngabdala Other Vehicles & General Automotive Discussions 35 05-18-2012 01:09 PM
