Old 01-19-2018, 01:43 AM   #1
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
LED Door Courtesy Light install
Vaaaroom
I am trying to install LED Door Courtesy lights, but not sure where to start. I am sure it should be easy, just take a bit of time to run the wire and install the LED light in the doors.
FRS2017 is offline   Reply With Quote
Old 01-19-2018, 02:50 PM   #2
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
here.
http://www.ft86club.com/forums/showt...light=courtesy
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
Chimera (01-19-2018)
Old 01-20-2018, 01:19 AM   #3
FRS2017
Enthusiast 86
FRS2017's Avatar
Maybe I need to plan this out more or understand it in detail.
I create a list of things needed and how to approach it, just not clear at the moment. I seen some LED lights on eBay that are pre-done for you. However some are saying if you use a white LED on the side doors you could get a fine?
Old 01-20-2018, 10:25 AM   #4
FRS2017
Enthusiast 86
FRS2017's Avatar
Good video guide that is basically very similar what I am trying to do
[ame="https://www.youtube.com/watch?v=C0lTXk85Ezs"]How to Install LED Logo Projectors in a BRZ & FR-S | BRZ FR-S Video Series (11) - YouTube[/ame]
Old 01-20-2018, 11:08 PM   #5
fx1mark
fx1mark's Avatar
so of you want the existing red light on the door to light up following that video. the only difference would be installing a 12 volt led bulb inside the existing light housing. yes I would use a white bulb. the lens is red so it will shine red. I would take the door card out before you start to see what you will need to do to properly install a bulb in the housing. It should be easy because on some cars it really does have a bulb in it. the only other thing I would do different from the video is I would run the wires behind the plastic and have them come out near the light. I would buy a male and female two pin socket and wire it so you can unplug the light when you remove the door card just like a factory install would be.
I may do this mod to my car.
Old 01-21-2018, 12:55 AM   #6
FRS2017
Enthusiast 86
FRS2017's Avatar
Hey,
The only issue about running the wire is I got carbon sound systems door deading material in the inner side and outside of the door. I wold have to try and remove it carefully, but not easy since its very sticky stuff.
I am looking into where I can get a 12 volt LED light socket or buy a new lense with socket.
Door trigger ground method is a better solution than running a wire to the cabin light.
Any idea where I might find a 12volt socket to connect the LED bulb to?
Old 01-21-2018, 01:23 AM   #7
FRS2017
Enthusiast 86
FRS2017's Avatar
https://www.ebay.com.au/itm/FT-86-FT...bx9c4Ga0KQOQWg
Something like this.....not sure if I want red or white. Really tempted on red
Old 01-21-2018, 01:32 AM   #8
fx1mark
fx1mark's Avatar
Originally Posted by FRS2017 View Post
Hey,
the bulb and socket is easy. my guess is it will be a T10 bulb and socket. a search on ebay shows thousands. As I said, I would pull one of the door cards off and look at the light housing. that will give you a good idea what you have to work with.
as far as the sound deadening, you don't have to run the wires behind it. you could just use tape to hold the wires in place.
Old 01-21-2018, 01:34 AM   #9
fx1mark
fx1mark's Avatar
why would you not use the light housing that is already installed? It's already there and fits perfect.
Oh I see, this is just a white version. It will be easy enough to change if you don't like it.
besides you can use the stock one as your test fitting.
if you use that light it will solve the bulb problem but you will need the socket that fits it.
Old 01-21-2018, 05:00 AM   #10
FRS2017
Enthusiast 86
FRS2017's Avatar
My current OEM setup has no socket, just a fake reflector or light cover that doesnt do anything
Old 01-21-2018, 10:41 AM   #11
fx1mark
fx1mark's Avatar
right, you would have to do a small amount of modification. I would have to see it, but it would probably be just drilling a hole to mount the bulb socket in. they make a kit for cars in the states that adds a bulb to the triangle fog light in the back. you drill a hole in the fixture where the bulb would be mounted and the bulb socket twists into place in the hole. I installed one in my car at one time. so it would be something similar. also leds are so reliable that even if it was a semi permanent mount (like hot glue) that wouldn't be a problem. just make sure the bulb does not touch anything inside. the fixture so it would look right and not melt anything.
again, we would need the pull the door card and take a look at it to see what it would take to do it.
Old 01-21-2018, 11:37 AM   #12
fx1mark
fx1mark's Avatar
I found this, he made a reflector but I don't really think it's necessary. I would have used metal duct work tape if I thought it was.
Also while searching a found out that if you short out the power that he was tapping into in the video, you could fry the computer. kinda scary.
http://www.ft86club.com/forums/showthread.php?t=36983
Old 01-22-2018, 06:05 AM   #13
FRS2017
Enthusiast 86
FRS2017's Avatar
Hey,
My reflectors are basically like one in that post, so maybe the sockets will fit?
$6 for this socket :
Seems all I need now is wire strippers and some electronic wire (certain length)
Old 09-10-2018, 10:49 PM   #14
713_GT86
713_GT86's Avatar
Drives: 2015 Series Blue BRZ
Vaaaroom
Attachment 162066
I know you mentioned you are on in the EU. By chance anyone know where I can grab a pair of the EU style Red courtesy Lens covers? Or will they fit up correctly on my 2015 Series blue ?
713_GT86 is offline   Reply With Quote
BRZ Driver's Door Courtesy Light Won't Work delusional Issues | Warranty | Recalls / TSB 31 05-29-2022 07:15 AM
D.I.Y. - BRZ courtesy door light bulb change joergasm DIY (Do-It-Yourself) Guides 24 09-13-2018 02:06 AM
FS: Brand New JDM 86 Courtesy Door Light Lamp - Clear Eric_FRS Interior Parts (Incl. Lighting) 6 02-15-2016 02:59 PM
Courtesy Door Light Help Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 5 03-16-2014 08:53 AM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
